  3. How to continue execute a skill script after a form popup...
  • Views 18476
How to continue execute a skill script after a form popup in layout ?
zgzg8312
zgzg8312 over 8 years ago
Hi,guys!
This my skill script!
procedure(self_align()
leHiAlign()
leAlignSelSetForm->layerField_2->value='(56628358 112 26 "NW (drawing)")
When I execute self_align(), the Align form popup, but the second statement was not executed,
just only I cancel the Align form ,the second statement just was executed.
But this is not I want,should I do?
Any help is good!
Gong
  • tweeksii
    tweeksii over 8 years ago in reply to Andrew Beckett +1
    I did not know about hiEnqueueCmd, so I had been using hiRegTimer for driving blocking forms. If hiEnqueueCmd is what I should have been using, than what is hiRegTimer's raison d'être ?
    Andrew Beckett over 8 years ago in reply to mbracht +1
    Max, Tom, hiEnqueueCmd is effectively the same as hiRegTimer with 0 as the time (sort of). What it does is insert a command into the queue of SKILL commands to be executed when the UI responds; it's…
    Hi Gong,
    I think you'd want to do:
      hiEnqueueCmd("leAlignSelSetForm->layerField_2->value=hiLayerMatchCyclicStr(leAlignSelSetForm->layerField_2->choices \"NW (drawing)\")")
      leHiAlign()
    I'm not sure which version you're using but in in recent IC versions it's changed to no longer by a layer cyclic field. So you'd do:
      hiEnqueueCmd("leAlignSelSetForm->layerField_2->value=\"NW drawing\"")
      leHiAlign()
  • zgzg8312
    zgzg8312 over 8 years ago in reply to Andrew Beckett
    Hi,Andrew!
    First method work for me!
    Thanks a lot!
    Gong
  • tweeksii
    If hiEnqueueCmd is what I should have been using, than what is hiRegTimer's raison d'être?
  • mbracht
    mbracht over 8 years ago in reply to Andrew Beckett
    Andrew,
    I don't quite understand why this works...cdnshelp says hiEnqueueCmd(<cmd>) executes <cmd> after returning from the current function which is self_allign(). However self_align() doesn't return any time before the blocking leHiAlign() returns. So what exactly does hiEnqueueCmd and when is <cmd> executed??
    thx
    Max
    Max, Tom,
    hiEnqueueCmd is effectively the same as hiRegTimer with 0 as the time (sort of). What it does is insert a command into the queue of SKILL commands to be executed when the UI responds; it's similar to the fact that you might have a blocking function (which doesn't return until the form has been OK'd for example) but yet you can still type SKILL functions in the CIW. It is not dependent upon self_align returning.
    Tom, hiRegTimer is still useful if you want to schedule something some time in the future (i.e. a non-0 number of 10ths of a second in the future). Also, if my memory is correct, hiRegTimer existed for a very long time but hiEnqueueCmd is relatively recent (I'm sure even that has been around for a long time though). So I tend to use it for its semantic benefits - it more clearly signals the intent when you read it in code.
  • zgzg8312
    Thanks,Andrew!
    That's great !!!!
    Gong
