  3. cutClass of vias through skill code
  • Subscribers 150
  • Views 18386
Leonardo Vinci
Leonardo Vinci over 8 years ago
I am trying to add via to my code as written below:
dbCreateVia(geGetEditCellView() viaDef1 list(pointx1 pointx2) "R0" list("cutRows" height "cutwidth" .048 "cutHeight" .024)) .................................................................(1)
pointx1 and pointx2 are coordinates. viaDef1 is also fine.
If i am using code till "R0" ie. if i am running this code:
dbCreateVia(geGetEditCellView() viaDef1 list(pointx1 pointx2) "R0")
then the code is working fine because i think its taking standard parameters. but when i am giving custom parameters as written below:
then the code (1) is giving me error as below:
*WARNING* (DB-270585): dbiListToStdViaViaParam:via parameter 1 - Invalid parameter for the viaDef.
I want to have Cut Class of my via as Bar/Rectangular via not not the standard square via(side .024um). Bar/Rectangualar cutclass has x width of .048um and y width of .024um.  Isnt there any parameter where cutClass is specified?
Thanks!
Leonardo da Vinci
  • psill000
    psill000 over 8 years ago +1
    You can change the cut with viaDB~>cutWidth and viaDB~>cutHeight Here are some older post that may help on getting techfile via cut dimensions https://community.cadence.com/cadence_technology_forums…
    Andrew Beckett over 8 years ago in reply to Leonardo Vinci +1
    It does tend to help if you actually show what you've tried, as then it would be much simpler to see what you'd done wrong. The cutSpacing needs to be a list of two values - the x and y spacing: viaparams…
    BTW, I did file CCR 1898684 with some suggestions on how to improve the documentation for dbCreateVia - I agree, it's a bit lacking in detail. Regards, Andrew.
  • psill000
    viaDB~>cutWidth and
    viaDB~>cutHeight
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/38209/how-to-know-the-cut-class-of-via-which-is-already-created/1353450#1353450
    Paul
  • Leonardo Vinci
    Leonardo Vinci over 8 years ago in reply to psill000
    i am using dbCreateVia function, and i am giving parameters like this:
    viaparams=list(list("cutRows" height) list("cutColumns" 1) list("cutWidth" .064) list("cutHeight" .032))...................................(1)
    In the documentation of dbCreateVia, i read that there is a parameter which we can pass as "cutSpacing".
    I am trying to give y spacing from via to via as .096um but if i add parameter "cutSpacing" the code of via doesnot run.
    code (1) runs smoothly, but if i add "cutSpacing" sublist too, then the code doesnt work.
    How to give via to via spacing in y direction using dbCreateVia function?
    Thanks!
    Leonardo da Vicni
    viaparams=list(list("cutRows" height) list("cutColumns" 1) list("cutWidth" .064) list("cutHeight" .032) list("cutSpacing" list(0.096 0.096)))
    Here I just specified both the x and y spacing as 0.096 - but you can of adjust as you need.
  • Leonardo Vinci
    Leonardo Vinci over 8 years ago in reply to Andrew Beckett
    Thank you Andrew! i was not giving list(x y). Now it works!
    As a suggestion to cadence documentation team, they should add an example for each parameter so that people like me who are new to SKILL can use the function without problems.
    Thanks once again!
    Leonardo da Vinci
