  3. the way to change display order of parameter in Results...
  • Subscribers 150
  • Views 15944
the way to change display order of parameter in Results tab of ADEXL
sjwprc
sjwprc over 8 years ago
     When I run corner sim in ADEXL, the parameters (e.g., Temperature, Design variable, parameters, Model Files ...) shown in Results tab is based on alphabetical order, when we have a big number of corners to sim, it is not easy to recognize the corner info. I wish to know how I can ensure these parameters are displayed as same order in the corner setup table.
BR
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    Currently I don’t see a way to get the corner parameters displayed in Results tab with same order defined in Corners setup. You could use the ‘Detail-Transpose’ instead of ‘Detail’ view to view your results, that’s an alternative way of displaying the results. It does not follow the order of the Corners setup but you can move the columns by dragging & dropping them.
    If you wish you can open a ticket on customer support and ask support to file an enhancement request, duplicate to CCR 1517740.
    Dimitra
  • sjwprc
    sjwprc over 8 years ago in reply to Dimitra Papazoglou
    Thanks for your comment, I don't think we need a new ticket exactly for this. However, I wish this can be updated in the new product.
