  3. using Alt for bindkey combination
  • Views 18240
Heywire
Heywire over 8 years ago
I am unable to use Alt for bindkey combination for a layout procedure.  I  went through your previous posts for using  "Alt for bindkey combination"  and tried loading
envGetVal("ui" "enableMenuShortcuts" stringToSymbol("boolean"))    in CIW ,   it returns t .
Regardless I also get below warnings and I am unable to use "Alt" combination for bindkeys.
*WARNING* Bindkey uses Alt modifier and will be ignored.
*WARNING* Invalid bindkey key string: AltShift<Key>0
Please give me a suggestion.
Thank you,
Anand
    Anand,
    Did you add this to a .cdsenv file or did you do an envSetVal() in the .cdsinit? This needs to be set in the .cdsenv (if I remember rightly) as otherwise it is set to late to have an influence. That's true - if you try to do it via envSetVal in the session, it will tell you via a popup. I just tested this again with a .cdsenv file and it works fine.
    Note that you need (normally) would need to put this in a .cdsenv file in your home directory; we normally don't read the .cdsenv in your working directory by default (this can be altered using the Cadence Search File mechanism or using $CDS_LOAD_ENV - see the documentation). So maybe that's what you've done wrong?
  • Heywire
    Heywire over 8 years ago in reply to Andrew Beckett
    Thanks for reply.  .cdsenv file in my home path is "read-only" ,it cant be edited. but i can see that  ui  enableMenuShortcuts stringToSymbol("boolean") is not present in .cdsenv.
    Yet envGetVal("ui" "enableMenuShortcuts" stringToSymbol("boolean"))    in CIW ,   it returns t.  When i do ls -lrt .cdsenv  it shows writable for me but this .cdsenv file is referring to common project folder and i cant edit this .csenv. Is there any work-around for this?
    Thanks in advance,
    Anand
    Andrew Beckett over 8 years ago in reply to Heywire
    Anand,
    Create a .cdsenv file in your working directory with the contents:
    ui enableMenuShortcuts boolean nil
    Then do:
    setenv CDS_LOAD_ENV addCWD
    or
    export CDS_LOAD_ENV=addCWD
    depending on the shell you're using (first is for csh, second is for bash/ksh). Then start virtuoso from that shell - this will tell it to read the .cdsenv in your working directory as well as the home directory.
    Note that  you would never put a SKILL function call such as stringToSymbol() in a .cdsenv file since it's not a SKILL file. In fact I'm not sure why you would do that even when doing envSetVal() because you could just as easily use 'boolean rather than stringToSymbol("boolean").
  • Heywire
    Thank you very much Andrew.
