  3. ComboField will not be updated
  • Views 15839
mschw
mschw over 8 years ago
I have discovered a strange behaviour of Combo Fields within my SKILL-Code. I was able to narrow it down in the following minimal example:
button=
hiCreateButton(
     ?name 'button
     ?callback "deleteFromComboFieldCB()"
    ?buttonText "Delete"
);hiCreateButton
comboField=
(hiCreateComboField
     ?name 'comboField
     ?items list("Element A" "Element B" "Element /" "Element %")
     ?prompt "Elements"
    ?editable nil
);hiCreateComboField
(procedure deleteFromComboFieldCB()
myform->comboField->items=
(remd
     myform->comboField->value
);remd
myform->comboField->value=car(form->comboField->items);for updating combo field
);procedure
form=
hiCreateAppForm(
     ?name 'myform
    ?fields list(comboField button)
    ?formTitle "Simple Form"
);hiCreateAppForm
hiDisplayForm(form)
This example consists of a ComboField and a Button. When I select "Element A" (or "Element B") in the ComboField and press the Delete Button "Element A"  will be removed from the ComboField (as expected). When I select "Element /" (or Element %") and press the Delete Button "Element /" is still a selectable item within the Combo Field. When I check all items of the Combo Field using SKILL (myform->comboField->items)  I can see that "Element /" was deleted from the items , but the GUI wasn't updated. Is there a reason for the different behaviour or am I doing something completely wrong?
I use IC6.1.7-64b.500.17
Many thanks in advance.
Kind regards,
Matthias
    Andrew Beckett over 8 years ago +1
    Matthias, Replace the remd() by remove(). remd is a destructive list operator, and I think it must be something to do with the fact that you are modifying the list in memory. What happens here is that…
    Matthias,
    What happens here is that the deletion only occurs properly if it's the first element that is being removed. That's consistent with the implementation checking to see if the pointer to the list of items changed - and if so, updating the choices in the combo-box; in the case of removing the first element, remd returns a pointer to the second element rather than the first so the list would have been seen as changed; in the case of removing anything other than the first, remd returns a pointer to the same list cell that it did before and I'm assuming this means that the UI doesn't think the list has changed. The actual ->items property is pointing to the SKILL list, so that appears to have been changed - it's just the actual items shown in the combo-box that don't change.
    Using remove() always returns a new list, so that always triggers the update.
    The dangers of side effects from destructive list functions!
  • mschw
    mschw over 8 years ago in reply to Andrew Beckett
    Andrew,
    thanks for your quick and detailed explanation. By replacing remd() with remove() everything works fine.
    Matthias
