  3. Deleting text label from selected object
  • Replies 7
  • Subscribers 150
  • Views 21734
Carona
Carona over 8 years ago
I was browsing around the forums looking for a simple solution, and I discovered this
txtLp = car(setof(lp cv~>lpps lp~>layerName=="text" && lp~>purpose=="drawing")) ;; get the text layer purpose database object
mapcar('dbDeleteObject txtLp~>shapes) ;; delete all labels and textDisplays
However this deletes all text from a virtuoso active window. I was hoping to modify this to only delete a text label from the selected object.
I can go into further detail as to why I would like that feature, but basically I want to perform a transformation on a shape and then add a label to the center of the shape.
So, I want to first delete an existing label, then create a new one.  I have the create a new label portion of code that works well.
This solution works with one shape, but if there are multiple shapes, every time I select a new shape to modify, its text label will be removed from the other shapes.
Thanks for your help
  • psill000
    psill000 over 8 years ago
    txtLp = car(setof(lp geGetSelSet()~>lpps lp~>layerName=="text" && lp~>purpose=="drawing"))
  • Carona
    Carona over 8 years ago in reply to psill000
    perfect!!! Appreciate the help.
  • Carona
    I spoke a lil too soon, I swapped in your line of code to replace my previous one and when I run it, the other texts no longer are deleted, but also, the current selected objects text also still remains.
    perhaps there is a better way of going about this, but I just want a way to have the selected object's text label deleted first.
    Then have a new text label generated at the new center point.
    1 - identify existing text of object, which you provided
    2 -  remove any text label, this is currently failing
    3 - generate new text label at center point, this I already have working.
    disp=dbCreateTextDisplay( net X list("text" "drawing" ) t centerBox(X~>bBox) "centerCenter" "R0" "roman" abs(dy/2) nil nil t nil t "name" nil) ;;Creates text label from net name of figure
  • psill000
    psill000 over 8 years ago in reply to Carona
    I am away from my computer, but try the line below, I deleted the "car(".
    txtLp = setof(lp geGetSelSet()~>lpps lp~>layerName=="text" && lp~>purpose=="drawing")
  • psill000
    psill000 over 8 years ago in reply to psill000
    and
    mapcar('dbDeleteObject txtLp)
    Andrew Beckett over 8 years ago in reply to psill000
    This approach is rather strange. What it's doing is finding the layer purpose pairs for all the selected objects, and then deleting all shapes (labels, textDisplays or anything) on those layer-purposes rather than either just those which are selected, or which have an association with the selected objects. I somehow doubt that's what you want.
    I'm guessing that you have the objects selected (but not the textDisplays) and want to delete the associated (attached) textDisplays. If so, code such as the following will do what you want:
    foreach(selObj geGetSelSet()
      foreach(child selObj~>children
        when(member(child~>objType '("label" "textDisplay")) && child~>layerName=="text" && child~>purpose=="drawing"
          dbDeleteObject(child)
    Note that this is deleting both attached labels and textDisplays - if you don't want it to do labels then you'd use when(child~>objType=="textDisplay" && ... . Needless to say the textDisplays have to be attached (which dbCreateTextDisplay does for you) for the relationship to be found - simply having them physically over the top of the object isn't enough.
  • Carona
    Carona over 8 years ago in reply to Andrew Beckett
    Yes, that is exactly what my intention was.  I wanted to first delete the text before I regenerated a new one, this solution does exactly that.  I need to go back and get more acquainted with
    the basics. Thanks for the help.
