  3. how to sort a list alphanumerically with bus names in descending...
  • Views 6229
how to sort a list alphanumerically with bus names in descending order using skill
RoseRivera
RoseRivera over 8 years ago
I have a list such as :  mylist=list("VDD" "GND" "ddd[0]" "ddd[1]" "ddd[2]" "bb[0]" "bb[1]" "bb[2]")
I try ==>  mylist=sort(mylist 'alphalessp)
the list become ==> ("GND" "VDD" "bb[0]" "bb[1]" "bb[2]" "ddd[0]" "ddd[1]" "ddd[2]")
I want mylist become ("GND" "VDD" "bb[2]" "bb[1]" "bb[0]" "ddd[2]" "ddd[1]" "ddd[0]"). The elements of the list
are sorted alphanumerically, but the bus names are sorted in descending order instead.
Thanks...
  • psill000
    psill000 over 8 years ago in reply to RoseRivera +1
    Here a bit of plagiarism of Andrews work may also work mylist = sort(mylist lambda((a b) minusp(alphaNumCmp(a b))))
  • DanielDing
    DanielDing over 8 years ago
    maybe something like the following?
    procedure( myLesspCompare( str1 str2 )
      let( (l_chars1 l_chars2)
        l_chars1 = parseString(str1 "[]")
        l_chars2 = parseString(str2 "[]")
        if( length(l_chars1)==1 && length(l_chars2)==1 then
          alphalessp(str1 str2)
        else
          if( length(l_chars1)==1 && length(l_chars2)>1 then
            t
           else
              if( length(l_chars1)>1 && length(l_chars2)==1 then
                nil
             else
                if( car(l_chars1)!=car(l_chars2) then
                  alphalessp(car(l_chars1) car(l_chars2))
                else
                   greaterp(atoi(cadr(l_chars1)) atoi(cadr(l_chars2)))
                );ifelse
              );ifelse
            );ifelse
         );ifelse
     );let
    );procedure
    mylist = sort( mylist 'myLesspCompare)
  • RoseRivera
    RoseRivera over 8 years ago in reply to DanielDing
    Thanks a lot, Daniel. Your solution works for my original list, but let's take another example
    mylist=list("VDD" "GND" "dd_b[0]" "dd_b[1]" "bb_a[0]" "bb_a[1]" "dd_abc" "bb_rst")
    the results after running your code will be ==> ("GND" "VDD" "bb_rst" "dd_abc" "bb_a[1]" "bb_a[0]" "dd_b[1]" "dd_b[0]")
    I want mylist become ("GND" "VDD" "bb_a[1]" "bb_a[0]" "bb_rst" "dd_abc" "dd_b[1]" "dd_b[0]").
    The elements of the list are sorted alphanumerically, and the name with bus quotation are sorted in descending order instead.
    Could you take a look again ...
    Best regards,
    Andrew Beckett over 8 years ago in reply to RoseRivera
    Use this comparison function:
    procedure(MySortCompare(a b)
      let((aSplit bSplit)
        aSplit=car(parseString(a "["))
        bSplit=car(parseString(b "["))
        cond(
          (alphalessp(aSplit bSplit) t)
          (aSplit==bSplit plusp(alphaNumCmp(a b)))
    Essentially if it matches before the [ then it uses alphaNumCmp to do the comparison - which by using plusp is going to give you the result in descending order of the bit that follows the [. For anything else, it's using alphalessp as normal.
  • RoseRivera
    RoseRivera over 8 years ago in reply to Andrew Beckett
    Thanks a lot,Andrew. It works like a charm.
  • psill000
    Andrew Beckett over 8 years ago in reply to psill000
    The complication with the original question was that numerical parts needed to be in descending order, with the alphabetic parts in ascending order. Your (much more compact) solution sorts them both in ascending order - which is of course fine if that's what you want!
