  3. How to use thick lines for highlighting functions: geAddHilightRectangle...
  • Views 21523
How to use thick lines for highlighting functions: geAddHilightRectangle / Path / PathSeg / Polygon, etc.
DanielDing
DanielDing over 8 years ago
I've been looking through the documents for a while without luck. Please kindly help:
When I use geAddHilightRectangle, it comes with thin line highlights in the layout. How to switch to thick lines?
I don't see such arguments in these functions as documented, nor does envSetVal("layout" "markNetThickline" 'boolean t) work..
Thanks much,
Duo
    The thickness is controlled by the display.drf packet definition for the layer-purpose you're using for the hilight set. You can however control the thickness of the halo if you use halos on the hilight set - e.g. using geSetHilightSetHaloParameters.
  • DanielDing
    DanielDing over 8 years ago in reply to Andrew Beckett
    Thanks much for the pointer, Andrew.
    In the same direction, I ended up using the following in an interactive SKILL session:
    drSetPacket("display" "y0" "blank" "thick2" "yellow" "yellow" "outline") to change the line thickness on "y0"/"drawing"
    or
    keep the original y0 as is, add another display packet and change highlight to it:
    drSetPacket( "display" "y0_thick" "blank" "thick2" "yellow" "yellow" "outline")
    geChangeHilightPacketName( hlightSetID "y0_thick")
