  3. How to read label inside a particular instance and check...
  • Subscribers 150
  • Views 17663
How to read label inside a particular instance and check its connectivity with the label of another instance
Garima M
Garima M over 8 years ago
Say, there are 2 instances with their terminals connected together using metal routing. There are labels placed over terminals in metal layer. Eg: "G" on GATE terminal, but there is no pin  over the terminals.
I want to read labels over those two connected terminals with their instance names & dump into a file.
Eg:   I1(Instance)  "G"(Label)  connected to I2(Instance)  "D"(Label)
I am new to assura, so I am looking for a code to implement above logic using assura. Please help with the same.
  • mbracht
    mbracht over 8 years ago
    Hi Garima, I don't quite understand what you mean - if you connect to instances then this metal routing connects the pin figures in the instances master cells.
    And what about those labels - are they in the instances master cells or in the current level? And in which way are they related to the instances?
    Can you please elaborate or provide an example...
  • Garima M
    Garima M over 8 years ago in reply to mbracht
    The instance which I am using is just some set of layers or pcell, It does not have any schematic.
    Labels are placed in that instance master cell to identify gate, source and drain area.
    Those labels are in metal layer and I will be defining connectivity of metal text with corresponding metal layer in geomConnect.
    If any net is connecting those two labels of different instances, I want to read label name and corresponding instance names.
    As of now there is no pin in instance master, If pins can ease the purpose I can place pins in instance master.
  • mbracht
    mbracht over 8 years ago in reply to Garima M
    Hi Garima, You may use dbGetOverlaps(..) to get at the shapes in the master cell that are overlapped by your metal routing, the below SKILL expression returns a list of those shapes:
    (foreach mapcar sl (dbGetOverlaps cv routingRect~>bBox '("Metal1" "drawing") 1:1) (cadr sl))
    Assuming there is the parent/child relation between label and shape you can then get at the corresponding labels with the shapes children attribute.
    This approach works for a routing shape which is a rectangle only - in case of more complicated shapes like pathes or polygons you'd have to turn those shapes into rectangles (dbLayerTile() does that...) first and then do the above for each resulting rectangle.
  • Amar Kumar
    Amar Kumar over 8 years ago
    Hi Garima,
    To be very clear , you are searching for a command or algorithm in ASSURA RULE WRITING to find whether 2 pins(not exactly pins,only the labels are placed over the routing layer) are connected not?
    You can find the direct command in ASSURA RULE WRITING to trace the connectivity for a label, but am not sure if there is any command or algorithm to find the connection between two labels with routing layer.
    If anyone can help, it will be very helpful for me too.
    Thanks & Regards,
    Amar
