  3. searching a list of sublists for matching expression
  • Subscribers 150
  • Views 19128
jaleco
jaleco over 8 years ago
Is there a simple way to search a set of sublists for matching expressions and return the list of sublists that have the expression?
I have been trying the following example and only get the full master list of sublists returned:
mylist='(("one" 1) ("two" 2))
myset=setof(list mylist foreach(item setof(obj list stringp(obj)) rexMatchp("one" item)))
==> (("one 1) ("two" 2))
  • tweeksii
    tweeksii over 8 years ago
    Try
    assoc("one" mylist)
  • tweeksii
    It looks like you were trying to do something like this:
    setof(list mylist
      destructuringBind((first second) list
        string(first) && rexMatchp("one" first)
    You could also write that this way:
    setof(list mylist
      stringp(car(list)) && rexMatchp("one" car(list))
  • jaleco
    jaleco over 8 years ago in reply to tweeksii
    thanks so much for your reply, great examples!
    I'm dealing with sublists that are a little less structured than my simple example, and I should have made the example strings longer.
    My sublist fields may vary, the number of field that matches the string may vary, and the string is a partial match.
    Presuming a more complex list/sublist and string search, this seems to work ok :
    foreach(list mylist foreach(item list if(stringp(item) && rexMatchp("match_this" item) then mynewlist=cons(list mynewlist))))
    (Of course, the newlist variable has to be initialized first)
  • mbracht
    mbracht over 8 years ago
    If you have no idea about the list structure (how many nesting levels etc...) I think you need to recursively walk through the list in question...try this one:
    (defun searchList (theList regex "lt")
       (let (sublists result)
          (if (exists el theList (stringp el) && (rexMatchp regex el)) then
             theList
          else
             sublists = (setof el theList (listp el))
             (while sublists
                result = (searchList (car sublists) regex)
                (when result
                   sublists = nil)
                sublists = (cdr sublists))
             result) ))
  • tweeksii
    tweeksii over 8 years ago in reply to jaleco
    I that case, I suggest the following:
    > mylist='(("one" 1) ("two" 2) (3 "buckle") (_ 4 "my") (_ _ 5 "shoe"))
    (("one" 1)
    ("two" 2)
    (3 "buckle")
    (_ 4 "my")
    (_ _ 5 "shoe")
    > setof(list mylist rexMatchList("e" setof(l list stringp(l))))
    (("one" 1)
    (3 "buckle")
    (_ _ 5 "shoe")
  • jaleco
    jaleco over 8 years ago in reply to mbracht
    great examples both - thank you! rexMatchList was handy.  I only have one level of hierarchy, but the recursive search example is much appreciated.
