  3. Remove double quotes from each element of list A
  • Views 20294
Leonardo Vinci
Leonardo Vinci over 8 years ago
I have a list(say, A), of 300 elements like below:
A=(
("a" "b")
("c" "d")
("e" "f")
("g" "h")
Like above, i have 300 elements, where 1st element is ("a" "b").
I want to create a list A without ""(double quotes), like shown below:
A=(
(a b)
(c d)
(e f)
(g h)
How can i do this?
LEO
    Andrew Beckett over 8 years ago in reply to Leonardo Vinci +1
    If you do an ordinary foreach, it will iterate over the outer list, but the return value will just be the original list, and the inner mapcar results will get lost. The foreach function allows the name…
    Leo,
    Assuming you really want to convert them all to symbols (not sure why you need to do that, but assume you have a good reason), you'd do:
    foreach(mapcar sublist A mapcar('stringToSymbol sublist))
  • Leonardo Vinci
    Leonardo Vinci over 8 years ago in reply to Andrew Beckett
    i don't understand how it works, 1st mapcar requires two parameters right?
    i understand this:
    foreach(sublist A mapcar('stringToSymbol sublist))
    that is, for each sublist in A, do mapcar.
    But i dont what you have done.
    If you do an ordinary foreach, it will iterate over the outer list, but the return value will just be the original list, and the inner mapcar results will get lost. The foreach function allows the name of a mapping function to be passed as the first argument before the loop variable, and in essence it's a convenient (to some people more readable) version of:
    mapcar(lambda((sublist) mapcar('stringToSymbol sublist)) A)
    In essence that's what it gets converted to - an anonymous function (lambda) is constructed from the loop variable and the body of the foreach, and then this lambda is applied to each element in the list A; the inner mapcar is then applied to each sublist to do the actual conversion from strings to symbols.
    Is that clearer?
  • Leonardo Vinci
    Yes, i understood the other way of writing, which you wrote. Thanks! :-)
