  3. How to select instances/figures from a schematic opened...
  • Subscribers 150
  • Views 5656
How to select instances/figures from a schematic opened in the background?
UmangKrSinha
UmangKrSinha over 8 years ago
Hi Skill experts,
Can someone suggest a way to select instances/figures from a schematic I opened using dbOpenCellViewByType() function?
I want my skill script to create a new schematic, use some other schematic and copy figures from there into the new one for editing.
I have searched the forum but couldn't find an answer to this specific problem.
I am a real rookie so If there is any better method to do this can you please suggest it?
Thank you
  • mbracht
    mbracht over 8 years ago
    What exactly do you mean with 'Select' - 'select' normally refers to clicking on a figure (which is not necessarily an instance - could also be a shape or via for example) in a graphic environment and in such add it to the so called selected set. That requires your design to be opened in a schematic editor however and dbOpenCellViewByType(..) doesn't open a design editor - it just returns a cellview data object. Now with that cellview data object you can get at the instances with
    cv~>instances
    As I said there are other figures (a figure is everything you can "select" in a graphic design editor) like vias, shapes and more..everyone has their corresponding database attribute to access it
    cv~>shapes
    cv~>vias
    cv~>markers
    etc...
    To open a cellview graphically you have to you the geOpen(..) function.
  • fungibleChattel
    fungibleChattel over 8 years ago
    Generally, in SKILL programming, the GUI functions are not very useful. There is usually a SKILL analog for them however. Once you have the cvID from dbOpenCellViewByType, you can cycle through the objects as mbracht has suggested and then use the proper SKILL function to operate on them. For Copying, for example, you can use dbCopyFig to copy from one cellview to the other.
  • UmangKrSinha
    UmangKrSinha over 8 years ago in reply to mbracht
    Thanks mbracht for your answer
    By "select" I meant selecting any type of figure (what clicking on a figure in a schematic view does, as you said)
    I will try using attributes to access the different figures, this is closest to what I want to do
    If this approach does not work however then I will have to resort to geOpen()
    Thanks again
