  3. Order of pCell callback triggering
  • Views 16133
abompos
abompos over 8 years ago
Hello Andrew,
First of all, needless to say, the set of abInvokeCDFCallbacks.il functions has been of great help!
I have a question though which relates to the callback triggering order performed by (abInvokeObjCdfCallbacks) and what's the recommended way to deal with interdependent CDF parameters.
The flow is as follows:
1. Create effective CDF by utilizing (abCreateEffectiveCDFLookalike)
2. Populate the values to be altered:
eff_cdf->X=20
eff_cdf->Y=30
3. Call the callbacks (abInvokeObjCdfCallbacks eff_cdf  ?order (list X Y))
During the first iteration, the 'X' callback is triggered, which by design, also alters 'Y' value and sets it to a value other than 30.  In the second iteration, the 'Y' callback will be triggered and operate on the value obtained previously. Hence, the value of 30 was actually never exercised.
In order to bring this "non-interactive" flow closer to what a user would normally do by hand (change X -> hit Apply -> change Y -> Hit Apply etc.), is the recommended way to call (abInvokeObjCdfCallbacks) recursively without utilizing the ?order argument, or am I missing something else here?
Thank you in advance,
Andreas
    Hi Andreas,
    You may need to do:
    eff_cdf->X=20
    (abInvokeObjCdfCallbacks eff_cdf ?order (list "X"))
    eff_cdf->Y=30
    (abInvokeObjCdfCallbacks eff_cdf ?order (list "Y"))
    Unfortunately interdependent CDF parameters are evil and a big headache when trying to call callbacks procedurally.
    Calling the callbacks with the ?order set to one parameter at a time as above is not any more expensive than calling it with an order list with two parameters - so that seems fairly reasonable to me.
    Hope that helps,
  • abompos
    abompos over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for the input! Much appreciated!
    Andreas
