  3. Virtuoso, monte carlo simulation to measure fervency of...
  • Views 17276
Virtuoso, monte carlo simulation to measure fervency of ring oscillator
Amin Zayed
Amin Zayed over 8 years ago
Hi
I have a problem, i can not measure the frequency of ring oscillator in monte calro simulation for a ring oscillator,
if i use the freq function in the calculator, the simulation not complete and give an errors.
Amin
    Amin,
    This doesn't make sense. Using the freq function in the calculator has nothing to do with the success or otherwise of the simulation. So it's unclear what your real problem.
  • Amin Zayed
    Amin Zayed over 8 years ago in reply to Andrew Beckett
    Hi Andrew
    I need to measure the frequency of ring oscillator in dc sweep simulation   ( frequency vs vol)
    thanks
    Andrew Beckett over 8 years ago in reply to Amin Zayed
    Well, that's very simple. You can't. Since a DC analysis is not time-varying, your oscillator will not oscillate and hence there will be no frequency to measure.
  • Amin Zayed
    Hi Andrew
    I need to make PUF (Physical Uncolnable Function ) and test it using monte carlo analysis
    so, i need to measure the frequency of ring oscillator vs the temperature variations .
    Many thanks
    Hi Amin,
    I assume you mean a Physically Unclonable Function (unless Uncolnable is some term I've never heard of) - not that this is terribly relevant to the question. I still don't understand why you think a DC sweep is suitable to measure the frequency of a ring oscillator.
    Normally you'd use either a transient simulation and then take the average frequency over a range of time after the oscillator has started, or better still use PSS oscillator mode and then use the expression on the direct plot form to find the frequency (this will find the steady state frequency). You could then run this in Monte Carlo in ADE XL, Explorer or Assembler, to get the variation of the frequency. If you want to see how that variation varies with temperature (and how the mean frequency varies with temperature), then you could sweep temperature as part of a corner (in ADE XL, Explorer or Assembler), or by sweeping the variable "temperature" in ADE Explorer or Assembler (in ADE XL you can't do a variable sweep at the same time as Monte Carlo, unless you do it within the corner definition).
    Please do read the forum guidelines. You'll find if you ask a well-formed question, in the right forum (I doubt you're really asking about the SKILL language), with enough information about what you're trying to do, what you've tried, and which tools and versions of the software you're using, then you're much more likely to get a focussed answer. Because you didn't provide any of this, anyone (including me) answering here has to guess what you really want...
    • Vote Up -1 Vote Down
