  3. selecting nets in schematics given netname
  • Views 17009
RAGHU2634
RAGHU2634 over 8 years ago
Hi ,
I have list with netnames of schematic. I need to select the net  in schematic given netname . Is there any function available to do this ?
Note: I  know about probing a net using geAddNetProbe() . Instead of this i need to select a net given netname
Raghu
  • skillUser
    skillUser over 8 years ago +2
    Hi Raghu, A net is a logical object not a physical one so there is not really a concept of selecting a net. However, what you probably intend is to select the wire shapes associated with a net? Here…
  • skillUser
    Hi Raghu,
    A net is a logical object not a physical one so there is not really a concept of selecting a net. However, what you probably intend is to select the wire shapes associated with a net? Here's a simple example to select wire shapes for "net07":
      mapcar('geSelectFig dbFindNetByName(geGetEditCellView() "net07")~>figs)
    Another way to achieve this is using the Navigator to select the net:
      hsmSelect(?type 'net ?name "net07")
    Hopefully this is what you are wanting to do?
    Best regards,
    Lawrence.
    • Vote Up +2 Vote Down
  • RAGHU2634
    RAGHU2634 over 8 years ago in reply to skillUser
    Hi ,
    Thanks. It worked . I mean wires in schematic as you said :-)
    thanks,
    Raghu
