  3. print value as binary formated
  • Views 17922
DavidLou
DavidLou over 8 years ago
hello export,
maybe impossible but just trying, from SKLANGREF, the printf could only do %d, %o %x for integer value, is there a way to print the integer as Binary formatted?
thanks,
David
  • skillUser
    skillUser over 8 years ago
    Hi David,
    Here's one way of getting a binary string for an integer (I'm assuming 32-bits):
    str = ""
    num = 17 ;; test value
    for(i 0 31
      if(onep(bitfield1(num i))
        str=strcat("1" str)
        str=strcat("0" str)
    str
    => "00000000000000000000000000010001"
    Hope this helps!
    Lawrence.
    Andrew Beckett over 8 years ago in reply to skillUser
    Very similar bit of code here that Lawrence beat me to it:
    /* abBinaryStrToInt.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 11, 2011
    Modified
    By
    Use bit field functions to convert to and from binary strings.
    Two functions:
    abBinaryStrToInt("1011") => 11
    abIntToBinaryStr(11 4) => "1011"
    SCCS Info: @(#) abBinaryStrToInt.il 02/11/11.11:56:48 1.1
    *                    abBinaryStrToInt(str)                     *
    *    Take a string of 1s and 0s and convert to an integer.     *
    procedure(abBinaryStrToInt(str "t")
        let((len (result 0))
            len=strlen(str)
            when(len>32 error("Cannot convert more than 32 bits"))
            for(i 1 len
                setqbitfield1(result case(substring(str i 1)
                    ("1" 1)
                    ("0" 0)
                    (t error("Illegal character %s in binary string" substring(str i 1)))
                    len-i
            result
    *          abIntToBinaryStr(val @optional (bits 32))           *
    *    Take an integer and convert to a string of 1s and 0s.     *
    *    An optional width of the resulting string can be given    *
    procedure(abIntToBinaryStr(val @optional (bits 32) "xx")
        let(((result ""))
            when(bits>32 error("Cannot convert more than 32 bits"))
            for(i 0 (sub1 bits)
                result=strcat(if(onep(bitfield1(val i)) "1" "0") result)
            result
  • DavidLou
    DavidLou over 8 years ago in reply to Andrew Beckett
    perfect, thanks Lawrence and Andrew.
