  3. Using Skill for Naming Large Numbers of Pins
  • Subscribers 150
  • Views 14805
sdineshkumar
sdineshkumar over 8 years ago
I am interested in learning how I could write a SKILL script to create a large numbers of pins to be used in a 1 KB 6t SRAM chip. These pins would then need to be individually named and connected to the correct instance pins. I currently have a single SRAM cell (schematic, layout, DRC and LVS completed), but expanding this to 1 KB has proven a challenge because I do not know how to create, connect, and correctly name the very large number of pins that would be necessary.
Is there a way to automate this process using SKILL?
Thank you
  • psill000
    psill000 over 8 years ago
    Is the cell VXL compliant?
    Are there pins in the lower cell?
    Paul
