  3. SKILL function for getting point ID (or netlist directory...
  • Replies 7
  • Subscribers 150
  • Views 21816
SKILL function for getting point ID (or netlist directory) in ADE XL
MinYoon
MinYoon over 8 years ago
I am writing custom SKILL function to process certain file located inside of netlist directory, in IC6.1.7-64b.
This file is generated by an internally developed tool of which source code I don't have access to.
I am calling my custom function in ADE XL output expression. This function needs to read the file, process data, and show result for each simulation point in ADE XL result window.
Let's say variables are defined as following.
ssName=axlGetWindowSession()
sdName=axlGetMainSetupDB(ssName)
hstName=axlGetHistoryName(axlGetCurrentHistory(ssName))
hstEntry=axlGetHistoryEntry(sdName hstName)
pCornerName=axlGetCornerNameForCurrentPointInRun()
When I run axlGetPointNetlistDir(hstEntry "test") when my test name is "test", I will get something like this.
"[some directory hierarchy]/adexl/results/data/Interactive.0/psf/test/netlist"
However I need to know the netlist directory of each point where each file is saved. Desired result looks something like this.
"[some directory hierarchy]/adexl/results/data/Interactive.0/1/test/netlist"
If I know point ID and run
axlGetHistoryEntry(sdName hstName ?cornerName pCornerName ?designPointId [point ID value])
I will be able to get the netlist directory I want.
Does anyone know if there is any function that returns point ID, or returns netlist directory of each simulation point?
Thank you.
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
     Try this:
    session=axlGetWindowSession()
    historyName=axlGetHistoryName( axlGetCurrentHistory(session))
    rdb=axlReadHistoryResDB(historyName)
    foreach(test rdb->tests()
      printf("Point %d Corner %L Test %s | The netlist directory is : %s \n" test->pointID test->cornerName test->name strcat( test->resultsDir "/netlist"))
    test->resultsDir returns the results directory of each sim point which is the dir that includes the netlist and psf folders. Using strcat I have added '/netlist'  to point to the netlist directory.
    Dimitra
  • MinYoon
    MinYoon over 8 years ago in reply to Dimitra Papazoglou
    Thank you for your suggestion.
    It looks like your code will return full list of netlist for each design points. However I think I need something slightly different.
    I am making a custom function that will show the result in ADE XL result window.
    For example, I would like to get something like this in ADE XL.
    Point VDD Process corner Power Output duty cycle Netlist Directory Some value from a file in the netlist directory
    1 1.6 SS 2.4 45 [???] [???]
    1 1,6 FF 2.5 55 [???] [???]
    2 1.8 SS 3 47 [???] [???]
    2 1.8 FF 3.1 54 [???] [???]
    3 2 SS 4 49 [???] [???]
    3 2 FF 4.3 51 [???] [???]
    In this example, I am sweeping three different VDD in two different process corners.
    I would like to measure three values in this example.
    I can use pre-defined Waveform Calculator function for simple expressions like "Power" and "Output duty cycle".
    I also would like to have some custom function that will read a certain file in the netlist directory and show certain value from that file in the same ADE XL window.
    Maybe I can use your code to generate separate text file that contains all the result.
    However I would need to open the result file after each simulation run, and I'd like to avoid that.
    Again, thank you very much for your answer.
    Dimitra Papazoglou over 8 years ago in reply to MinYoon
    Ok it's clearer now what you are trying to do.
    You can add the following output for each of your tests in Outputs Setup tab in ADE-XL:
    asiGetNetlistDir(asiGetCurrentSession())
    The above returns the netlist directory for each designPointId-Corner for the associated test.
    Also, Instead of calling again asiGetNetlistDir(asiGetCurrentSession()) in your custom function which reads value(s) from a file from netlist directory, you can use calcVal() as input argument in the custom function to propagate the netlist directory.
    e.g
    In Outputs Setup tab:
    netlistDir= asiGetNetlistDir(asiGetCurrentSession())
    MyReadValue=dpReadValueFromFileInNetlistDir(calcVal("netlistDir"))
    In the above example, you might not really need calcVal() - so dpReadValueFromFileInNetlistDir( netlistDir ) would be enough - but some things are not working always without calcVal() so I'll advise you to use it.
    Dimitra
  • MinYoon
    I've tried your suggestion with limited success.
    Let's say I am running a test named "test_tran" at "Interactive.0". I will assume that four different corners will be run as a result of this simulation.
    The result directory will look like this.
    • Interactive.0
      • 1
        • test_tran
          • netlist
          • psf
      • 2
        • test_tran
          • netlist
          • psf
      • 3
        • test_tran
          • netlist
          • psf
      • 4
        • test_tran
          • netlist
          • psf
      • psf
        • test_tran
          • netlist
          • psf
    Before running the simulation, I defined a new expression called "netlistDir" as asiGetNetlistDir(asiGetCurrentSession())
    As each simulation ends, "netlistDir" will correctly point to each directory, namely...
    - [some hierarchy]/Interactive.0/1/test_tran/netlist
    - [some hierarchy]/Interactive.0/2/test_tran/netlist
    - [some hierarchy]/Interactive.0/3/test_tran/netlist
    - [some hierarchy]/Interactive.0/4/test_tran/netlist
    However, when I re-evaluate the expression after all the simulations have ended, they will all point to same directory, which is...
    - [some hierarchy]/Interactive.0/psf/test_tran/netlist
    The same expression is giving me different result depending on when it was evaluated. Therefore it can cause unexpected error especially when I want to add a new expression that refers to netlistDir after the simulation is done.
    If it can work correctly all the time, then it will solve all of my problem. I believe we are getting closer to the solution.
    Thank you so much for your expert advice.
    Andrew Beckett over 8 years ago in reply to MinYoon
    That's a good point. Dimitra and I had talked about this, and I'd always used the approach with asiGetCurrentSession(), but overlooked the fact that re-evaluate doesn't work properly because asiGetCurrentSession is pointing at the global point then. For the case I'd been using it previously, which was used with calcVal to pass a spectre nodeset from one simulation toa another, that didn't matter, because it was only used in simulation and re-evaluation didn't matter - but clearly it does in your case.
    Instead, you can use openResults() or sprintf(nil "%s/netlist" openResults()) if you need the netlist dir, or similar for the psf dir. That should work with both the post-simulation and re-evaluation situations, I believe (seems fine from a quick test).
  • MinYoon
    MinYoon over 8 years ago in reply to Andrew Beckett
    I've tried openResults() and it works perfectly
    Thank you so much for your help. I've been working on this for weeks, and it will reduce the script length by a lot.
  • nunger23
    nunger23 over 6 years ago in reply to Andrew Beckett
    Hey Andrew,
    sorry for bothering but I do have a follow up question.
    Actually your proposed command works fine to get the "point" result directory post simulation and as well when re-evaluating expressions. Now, I did tried to use the same to get the result of an ASCI file plotted which I'm storing during run time via an VerilogA script.
       sprintf(nil "%s/psf" openResults())
       getAsciiWave(strcat(resDir3 "/strobe.asc") 1 2 ?xskip 0 ?yskip 0 ?formatFloat nil ?xName "Iload" ?xUnits "A" ?yName "Efficiency" ?yUnits "pc")
    First expression above works perfectly and second seems to work post simulation as it appears I'm getting the right data type into the Maestro session. Only when I do plot the waveform (via right mouse button klick --> plot) it will become re-re-evaluated and here I'm getting to the general psf directory and not the point directory. Running the same command from ICFB window or the calculator works perfectly fine when I'm using the correct data path.
    Anything I could add or do different to have direct access via the getAsciiWave?
    Thanks in advance,
    Norbert
