  3. Automatically generating pins from nets problem
  • Views 19202
Nicolas Callens
Nicolas Callens over 8 years ago
Hello everyone,
I wanted to write a SKILL code that generates automatically your pins depending on the selected nets and the place where you clicked. However, the latter one does not work and the pins get generated somewhere else in the schematic... Underneath you can find the important part of my code where the problem is situated:
procedure(schAutoCreatePins(ok theListBox)
let( (xcoord ycoord inputCVId)
    xcoord = xCoord(hiGetCommandPoint())
    ycoord = yCoord(hiGetCommandPoint())
    inputCVId = dbOpenCellViewByType("basic" "iopin" "symbol" "" 'r)
    if( ok then printf("Creation of pins: \n")
       foreach(choice theListBox->value
       sprintf(namePin "%s" choice)
       schCreatePin(geGetEditCellView() inputCVId namePin "inputOutput" nil xcoord:ycoord "R0")
       ycoord = ycoord + 0.25
       printf("Pin %s\n" namePin)
       ) ; foreach
    else printf("Cancelled automated pins creation.")
    ) ; if
) ; procedure
Kind Regards,
Nicolas
    Andrew Beckett over 8 years ago in reply to Nicolas Callens +1
    Nicolas, I changed the code to use an enter function - so it prompts you to click on a point to start placing the pins. Better still would be to have started with the enterPoint and then have an options…
    Hi Nicolas,
    First of all, you should not write your own code using the same prefixes as Cadence (so don't create your own functions with prefixes such as "sch"). The whole point of using prefixes is to reduce the chance of clashes - and you've then named your function with an increased likelihood of a clash with a future function from Cadence.
    Secondly, if you're calling this from an enter function (e.g. enterPoint), why not use the point that was provided to the callback? It's not that clear how  you're calling the function you show - perhaps you can provide more details?
  • Nicolas Callens
    Nicolas Callens over 8 years ago in reply to Andrew Beckett
    1. In the meantime I have followed your advice concerning the prefixes
    I have added the full code, with some additional comments:
    ; Generates List Box with callback cstAutoCreatePins(). TrShowPinListBox(netList) creates list box in which you can select the nets to be generated as pins by cstAutoCreatePins()
    procedure(TrShowPinListBox(netList)
        hiShowListBox(
            ?name gensym('cstPinListBox)
            ?choices netList
            ?callback 'cstAutoCreatePins
            ?title "Net to pin transformation"
            ?multipleSelect t
            ?applyButton t
        ) ; hiShowListBox
    ) ; procedure
    ; When clicking on certain place in schematic of cellview, the point should be retrieved by hiGetCommandPoint(). This point should be the location where the first pin should be situated, all other pins are above this "reference point", each with an incremental step of 0.25 (as implemented in the code)
    procedure(cstAutoCreatePins(ok theListBox)
        let( (xCo yCo inputCVId)
        xCo = xCoord(hiGetCommandPoint())
        yCo = yCoord(hiGetCommandPoint())
                     schCreatePin(geGetEditCellView() inputCVId namePin "inputOutput" nil xCo:yCo "R0")
                     yCo = yCo + 0.25
                ) ; foreach
            ) ; if
    ) ; procedure
    ; Just generates the list of nets and call the list box, in which you select the nets to be generated as pins each with an 0.25 increment above each other.
    procedure(cstLoadTrShowPinListBox()
        cv = geGetWindowCellView()
        netNames = cv~>nets~>name
        TrShowPinListBox(netNames)
    Hopefully, I have made myself clearer.
    Thanks!
    Kind regards,
    Nicolas
    Nicolas,
    I changed the code to use an enter function - so it prompts you to click on a point to start placing the pins. Better still would be to have started with the enterPoint and then have an options form to ask you the nets you wanted to create the pins for, but that was a little more work to create the form (as then you'd need to create the form and have a listbox field within the form rather than using hiShowListBox) - not much, but I didn't have time.
    I think the problem with using hiGetCommandPoint is that if the focus moves away from the window, it won't work.
    Here's the updated code:
        hiShowListBox(
            ?choices netList
            ?multipleSelect t
            ?applyButton t
        ) ; hiShowListBox
    ) ; procedure
        let( (xCo yCo inputCVId pointList)
            when(ok
                pointList=enterPoint(?prompts list("Enter point for first pin"))
                unless(pointList ok=nil)
                xCo = xCoord(pointList)
                yCo = yCoord(pointList)
                     yCo = yCo + 0.25
                ) ; foreach
            ) ; if
    ) ; procedure
    Alternatively, could use code similar to yours (I'm assuming you're calling cstLoadTrShowPinListBox() from a bindkey), but record the coordinate early in the code, like this:
        hiShowListBox(
            ?choices netList
            ?multipleSelect t
            ?applyButton t
        ) ; hiShowListBox
    ) ; procedure
        xCo = xCoord(cstLoadTrShowPinListBox.coord)
        yCo = yCoord(cstLoadTrShowPinListBox.coord)
                     yCo = yCo + 0.25
                ) ; foreach
            ) ; if
    ) ; procedure
        cstLoadTrShowPinListBox.coord=hiGetCommandPoint()
    Finally, I should point out that "cst" is one of our prefixes too! Better to use a prefix that begins with an uppercase letter, as then it won't clash with a Cadence prefix.
  • Nicolas Callens
    Thanks Andrew, I really appreciate the effort you have taken! I will try to implement it with the enterPoint function like you have suggested.
    Kind regards,
    Nicolas
