  3. Convert output of "waveVsWave()" into derivable waveform...
  • Views 6086
Convert output of "waveVsWave()" into derivable waveform by ordering X and Y values
dontpanic
dontpanic over 8 years ago
Hi all! I'd like to take the derivative of waveforms that I obtain using the waveVsWave() function. The problem is that using the "deriv()" function doesn't work (I guess) because the X and Y values of such waveforms are not properly arranged.
For example: in a TRAN simulation of an SC amplifier I get input and output waveforms Vout(t) and Vin(t), and use waveVsWave() to obtain a plottable "Vout(Vin)" waveform. However, using deriv() on it produces incorrect results, I suspect because the X values of the waveform are not monotonic, but arranged according to the original independent variable "t" (e.g. for a coherently-sampled sine input at Nyquist frequency the X values alternate polarity with every sample, and so do the corresponding Y-values at the output of the amplifier).
In the above example, how could I process the output of waveVsWave() so that I can use deriv() to calculate dVout/dVin = effective gain of the amplifier, including distortion components (different from Vout/Vin ratio!)?
I suspect all what is needed is a skill function to process the "Vout(Vin)" waveform (so as to order its elements: X-values monotonically, and Y-values according to the ordering of the X-values), but this goes beyond my Skill capabilities.
Thanks and regards,
Jorge.
    Andrew Beckett over 8 years ago +1
    Hi Jorge, You could use the code in this article: 11584412 . I'll post both bits of code here that are needed - hopefully this will solve the problem for you? /* abSortXValues.il Author A.D.Beckett…
    Hi Jorge,
    /* abSortXValues.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Aug 26, 2009
    Modified
    By
    Function to sort the inner sweep to be sorted by x-value.
    For harmonic data (such as that from pac, qpac), the order is
    by harmonic number - so if you try to use the value() function,
    you may get garbage results because value() expects the x-axis
    to be monotonic.
    Usually you would use the harmonic() function to get a particular
    harmonic - this is to allow you to get a fixed frequency instead
    (if you're doing a sweep of frequency, you may not be interested
    in a fixed harmonic id).
    Usage:
    a=abSortXValues(v("/net6"))
    plot(value(a 100k))
    Uses abWaveToList.il
    SCCS Info: @(#) abSortXValues.il 08/26/09.12:32:13 1.1
    (defun abSortXValues (wave)
      (cond
        ((drIsWaveform wave)
         ; Sort each waveform to be ordered by the x-values
         (artListToWaveform (sortcar (abWaveToList wave) 'lessp))
        ((famIsFamily wave)
         (let (new)
           (setq new (famMap 'abSortXValues wave))
           ; Remove any harmonic information, because it won't be correct
           ; as the order of the underlying waveforms no longer matches
           (remprop new 'harmonic)
           (remprop new '__harmonicList)
           new
        (t
          (error "abSortXValues - can't handle %L\n" wave)
        ) ; cond
      ) ; defun
    /* abWaveToList.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 17, 2003
    Modified
    By
    Convert a waveform to a list
    SCCS Info: @(#) abWaveToList.il 11/17/03.15:08:15 1.1
    *                  (abWaveToList wave @key transpose)                   *
    *    Take a waveform object, and return it as a list of xy pairs. Or    *
    * if transpose is set, it returns a list of x values followed by a list *
    *                             of y values.                              *
    (procedure (abWaveToList wave @key transpose)
      (let (xList yList xyList len
            (xVec (drGetWaveformXVec wave))
            (yVec (drGetWaveformYVec wave))
           (setq len (drVectorLength xVec))
           ; Return value of this if is the list
           (if transpose
               (progn
                (for i 0 (sub1 len)
                     (setq xList (tconc xList (drGetElem xVec i)))
                     (setq yList (tconc yList (drGetElem yVec i)))
                (list (car xList) (car yList))
               ; else
               (progn
                (for i 0 (sub1 len)
                     (setq xyList (tconc xyList (list (drGetElem xVec i)
                                                      (drGetElem yVec i))))
                (car xyList)
               ) ; if
           ) ; let
      ) ; procedure
  • dontpanic
    dontpanic over 8 years ago in reply to Andrew Beckett
    Thanks a million, Andrew! Worked like a charm!!! Smiley
