  3. removing repetitions from list with same elements but in...
  • Views 16156
removing repetitions from list with same elements but in reverse order
RAGHU2634
RAGHU2634 over 8 years ago
I have a list which looks like this.
for example
a=( (1  2) (2  1)  (1  3)  (3  1) ) .  I need a function to transverse this list  as shown
a=( (1 2) (1 3) )  or a = ( (2  1)  (3  1) )
Raghu
  • skillUser
    skillUser over 8 years ago +1
    Hi Raghu, Assuming that 'a' is the original list of four sub-lists you can return the 'odd' or 'even' elements like this: idx=0 setof(item a idx++ && oddp(idx) && a) => ((1 2) (1 3) ) idx=0 setof…
  • RAGHU2634
    RAGHU2634 over 8 years ago in reply to skillUser +1
    Hi lawrence, That is just an example i gave . I am not dealing with numbers in real. Idea is to filter list with same elements i.e; removing repetition Thanks, Raghu
    Andrew Beckett over 8 years ago in reply to RAGHU2634 +1
    Hi Raghu, Your description in the original post was rather unclear - I assumed the same as Lawrence. Something like this is probably what you want? procedure(CCFfilterReversedLists(l) let(((revListTable…
  • skillUser
    Hi Raghu,
    => ((1 2)
        (1 3)
    idx=0 setof(item a idx++ && evenp(idx) && a)
    => ((2 1)
        (3 1)
    Best regards,
    Lawrence.
  • RAGHU2634
    Hi lawrence,
    Raghu
    Hi Raghu,
        let(((revListTable makeTable('reversedLists nil)))
            setof(sublist l
                unless(revListTable[sublist]
                    when(listp(sublist)
                        revListTable[reverse(sublist)]=t
                    t
  • RAGHU2634
    RAGHU2634 over 8 years ago in reply to Andrew Beckett
    Thank you so much Andrew.This is what i exactly wanted.
    Raghu
