  3. Generating Schematic pin list
  • Views 24409
LakshmanQual
LakshmanQual over 8 years ago
Hi Team, I am generating the pin list from schematic as
cv=geGetEditCellView()
pins=cv~>terminals~>name .
If any bus is input or output, its coming directly as a bus only like Q<3:0>. But i want them as individual pins like Q<0> Q<1> Q<2> Q<3>.
There are 10's of buses in schematic, so i want all of them to come as individual pins.
Is there any way to generate them as individual pins? I want them to compare with layout pins?
    Are you asking how to create pins on the schematic, or just how to get a list of the member names? I think it's the latter you're asking for, then:
    dbProduceMemName("Q<3:0>")
    which outputs:
    ("Q<3>" "Q<2>" "Q<1>" "Q<0>")
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for the reply. Sorry that the question was not clear.  I want to list the schematic pins. But using the general code, the pins were coming as bus directly.  But those pins should be separated in my list to compare them with layout pins. With the piece of code you had given, i ran that code using foreach loop on entire list which includes buses. Now my final aim reached because of your idea of "dbProduceMemName". Thank you Andrew!!!
  • iDave
    iDave over 8 years ago in reply to Andrew Beckett
    Assuming that I have a list like (“q<1>“ “q<0>”), Is there any function that can rebuild it to q<1:0>?
    Andrew Beckett over 8 years ago in reply to iDave
    Here's a bit of code I wrote a little over 10 years ago to do this (the comment at the top which talks about the case of nets is related to the code that this was part of, so you can ignore that):
    There's nothing built in which does it though. Make sure this code goes in a file with an ".ils" suffix, so that when loaded it uses SKILL++ semantics (needed for the local function that is defined within the outer function). Without that, it may not work...
    *              abCollapseAdjacentSignals(sigNames)              *
    *   A wild attempt to reduce an expanded set of member names    *
    * to a shorter net name expression. Will spot simple sequences, *
    *   such as adjacent repetitions and bus ranges, but will not   *
    *  spot repeated sequences of signals (e.g. will not collapse   *
    *  a,b,a,b to <*2>(a,b) ). This is used after having converted  *
    * the case on internal/external signals to recreate wire labels *
    defun(abCollapseAdjacentSignals (sigNames)
        let((prev prevBusRoot curBusRoot prevBusInd curBusInd
            prevDelta curDelta startInd sigList indCount curBusInfo)
            *             addToSignalList (sigList root busInfo)              *
            *  Local function which updates a signal list, for a given root   *
            * and collected bus information. busInfo will contain information *
            *      about repeated (simple) sequences and bus ranges etc.      *
            defun(addToSignalList (sigList root busInfo)
                ; Each entry in the busInfo is of this form
                ; list(startInd prevBusInd prevDelta indCount)
                let((sigName busRanges)
                    if(!cdr(busInfo) && !caar(busInfo) then
                        if(cadddr(car(busInfo))==1 then
                            sigName=root
                        else
                            sprintf(sigName "<*%d>%s" cadddr(car(busInfo))
                                root)
                    else
                        busRanges=foreach(mapcar busData busInfo
                            cond(
                                (caddr(busData)==nil || caddr(busData)==0 &&
                                    cadddr(busData)==1
                                    sprintf(nil "%d" cadr(busData))
                                    sprintf(nil "%d*%d" cadr(busData)
                                        cadddr(busData)
                                (caddr(busData)==1 || caddr(busData)==-1
                                    sprintf(nil "%d:%d" car(busData) cadr(busData))
                                (t
                                    sprintf(nil "%d:%d:%d" car(busData)
                                        cadr(busData) abs(caddr(busData))
                        sprintf(sigName "%s<%s>" root
                            buildString(busRanges ",")
                    sigList=tconc(sigList sigName)
            prev=car(sigNames)
            rexCompile("^\\([^<]*\\)<\\(.*\\)>$")
            if(rexExecute(prev) then
                prevBusRoot=rexSubstitute("\\1")
                prevBusInd=atoi(rexSubstitute("\\2"))
            else
                prevBusRoot=prev
                prevBusInd=nil
            startInd=prevBusInd
            prevDelta=nil
            indCount=1
            foreach(sigName cdr(sigNames)
                if(rexExecute(sigName) then
                    curBusRoot=rexSubstitute("\\1")
                    curBusInd=atoi(rexSubstitute("\\2"))
                else
                    curBusRoot=sigName
                    curBusInd=nil
                if(curBusRoot==prevBusRoot then
                    if(curBusInd && prevBusInd then
                        curDelta=curBusInd-prevBusInd
                    else
                        curDelta=nil
                    if(!prevDelta || curDelta==prevDelta then
                        indCount++
                    else
                        ; Record previous range, and then start again
                        curBusInfo=tconc(curBusInfo
                        startInd=curBusInd
                        indCount=1
                        curDelta=nil
                    prevDelta=curDelta
                    prevBusInd=curBusInd
                else
                    sigList=addToSignalList(sigList prevBusRoot car(curBusInfo))
                    curBusInfo=nil
                    prevBusRoot=curBusRoot
                    prevDelta=nil
                    indCount=1
                    startInd=prevBusInd
            ; Record previous range, and then output
            car(sigList)
