  3. Reading Warning Messages from CIW using SKILL
  • Views 21962
KGh94
KGh94 over 8 years ago
Is it at all possible to read the warning messages that pop up in CIW? I would like to use those messages for debug purposes.
Something like read(woport)
Best regards,
Karam
    Andrew Beckett over 8 years ago in reply to KGh94 +1
    Hi Karam, Assuming that the warning appears in the orange colour in the CIW, then you should just be able to do: theWarning=CCFcaptureWarnings( CCSinvokeInstCdfCallbacks(myInstance) ; invoke cdf callback…
    Hi Karam,
    One way is to write a macro which redirects the woport temporarily to a string port:
    defmacro(CCFcaptureWarnings (@rest body)
      `let(((tempPort outstring()))
        unwindProtect(
          ; main clause - using dynamic scoping, redirect woport to tempPort
          ; and then invoke the forms passed in as the argument to the
          ; macro
            let(((woport tempPort))
              ,@body
              ; next two lines are to force final warning to be flushed
              warn("")
              getWarn()
            ; return value is the data written to the string port
            getOutstring(tempPort)
          ; always execute the close even if there was an error in
          ; the code above
          close(tempPort)
    This uses dynamic scoping to ensure that woport is returned to its original value. Then you can wrap the code which is generating the warnings as follows, and the return value is the captured warnings:
    a=CCFcaptureWarnings(
      warn("hello\n")
      warn("world\n")
      warn("testing 123\n")
    The variable a contains the text of the warnings.
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your quick response, and apologies for my slow reply. The code you provided works if I am the one issuing the warnings. However, I am trying to read the warnings that the tools generate. For example, when the Schematic Editor issues a warning about floating nets. I would like to read the information contained in that warning message using SKILL.
    Any hints would be appreciated.
    Best regards,
    Karam
    Hi Karam,
    If you call a Cadence SKILL function that generates warnings (e.g. a schematic SKILL function) then the code I provided would also capture the warnings.
    Presumably you want to capture the warnings during the invocation of some schematic editor command? If not, please clearly describe what you're doing and how you'd expect to capture the warnings for this.
  • KGh94
    Hello Andrew,
    My apologies for the confusion, I'll try to clarify on the purpose.
    myInstance = dbCreateInst(cellView instanceID deviceName x:y orient)         ; creating an instance
    myInstance->width = "100u"                                                   ; set instance width
    Then I get a warning message in CIW: *Warning* Width too large
    So the idea would be to somehow get that warning into my SKILL code
    Best regards,
    Karam
    Hi Karam,
    However, it's possible that the CDF callback code in the PDK you're using is not using warn() to print messages but is just printing a string using printf that happens to have the text "*Warning"" in it (in which case the text would come out in black in the CIW); it's the warning port (woport) that shows in orange normally.
    I've assumed it was the CDF callback that produced the warnings - you could put the whole block of code above inside CCFcaptureWarnings if you wish.
  • KGh94
    Wow, it worked. You're a wizard, Andrew!
    Thanks a lot! Smiley
