  3. how to find floating pins in layout
  • Views 17908
acom
acom over 8 years ago
Hello ,
We would like to find float pins in layout.For example, there is 2 pins which are both named as "testpin" in the layout.
But one is connected to metal , another is floating which means it doesn't connect to anything.
How can i find the pin which is not connected to anything else by using skill?
  • Marben
    Marben over 8 years ago
    Hi acom,
    Check this out, originally created by Quek.
    Hope this help.
    Best regards,
    Marben
    procedure( CCSfindPins()
             let( (cv allPins count overlapShapes)
                cv=geGetWindowCellView()
                allPins=setof(x cv~>shapes x~>pin
                count=0
                foreach( pin allPins
                   overlapShapes=dbGetOverlaps(cv pin~>bBox pin~>lpp 0:32)
                   unless( length(overlapShapes)>1
                      geSelectFig(pin)
                      count++
                      printf("Isolated %L pin with net %s found at %L\n"
                           pin~>lpp pin~>net~>name centerBox(pin~>bBox))
                   ) ;unless
                ) ;foreach
                printf("%n isolated pin(s) selected in cell %s\n"
                                                         count cv~>cellName)
             ) ;let
          ) ;procedure
          hiSetBindKey("Layout" "F10" "CCSfindPins()")
  • acom
    acom over 8 years ago in reply to Marben
    That works great.Thanks !!!
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Marben
    Hi Marben, Its showing all the pins even though they are connected to nets.
  • Marben
    Marben over 8 years ago in reply to LakshmanQual
    Hi LakshmanQual,
    Check this out.
    Hope this help.
    Purpose : Find floating pins in the layout by its connectivity.
    How to run : 1. load "/home/eda/SKILL_VXL/float_pins_check.il"
                           2. fc()
    Date created : June 2, 2018
    Author : Marben F. Orallo
    ; load "/home/eda/SKILL_VXL/float_pins_check.il"
    procedure(fc()
     ; pin_name = "Ch1"
     cv = geGetEditCellView()
     pins = cv~>terminals~>pins
     pins_flatten = CCSflattenList(pins)
     pin_id = setof(x pins_flatten x~>name)
     incomplete_nets = lceGetIncompleteNets(cv)~>name
     foreach( pin_id pin_id
      netname = pin_id~>net~>name
      exist = member( netname incomplete_nets )
      if( exist != nil then
       ; printf("\n exist me = %L", exist)
       loc = centerBox(pin_id~>fig~>bBox)
       printf("\n Connection found, connection is not yet finish. %L %L" pin_id~>name loc)
     ) ;if
     ) ;for
    ) ;proc
    procedure(CCSflattenList(l)
      if(listp(l) mapcan('CCSflattenList l) list(l))
