  3. How to manipulate a "OneDDualArrayTblValue"
  • Views 1113
WTony
WTony over 8 years ago
Does it exist some API which let me manipulate a OneDDualArrayTblValue?
let's say I have that table:
((("width") ((0.0 0.0) ) )
 ( 0.01 ((0.01 0.02) )
   0.02 ((0.02 0.03) )
   0.04 ((0.05 0.06) )
   0.05 ((0.06 0.07) (0.07 0.07) )
   0.06 ((0.04 0.02) )
   0.07 ((0.03 0.02) (0.06 0.04) )
   0.08 ((0.02 0.02) )
what is the best way to insert a member (0.03 ((0.02 0.04) (0.05 0.05) ) ) between the member (0.02 ((0.02 0.03) ) ) and  (0.04 ((0.05 0.06) ) ).
Do I have too break the table and read each member then append when find the right position in a for loop.
Any suggestion is welcome.
Tony
    Hi Tony,
    Not entirely sure what you're referring to when you talk about a OneDDualArrayTblValue - i.e. what's the context? This is not a table (in the SKILL sense), it's a list of lists. You could insert the value something like this:
    data='((("width") ((0.0 0.0) ) )
       0.02 ((0.02 0.03) )
       0.04 ((0.05 0.06) )
       0.06 ((0.04 0.02) )
       0.08 ((0.02 0.02) )
    newRow='(0.03 ((0.02 0.04) (0.05 0.05) ) )
    tableList=cadr(data)
    position=0
    rplacd(data
      foreach(mapcan elem tableList
        if(evenp(position++) && newRow && elem>car(newRow) then
          prog1(
            append1(newRow elem)
            newRow=nil
        else
          list(elem)
    This is a bit clunky - the mapcan is just a way of iterating over the original list and either keeping the original value, or splicing in the new "row". I'm then using rplacd to insert it in place.
  • WTony
    WTony over 8 years ago in reply to Andrew Beckett
    Thanks Andrew
    It's exactly what I want.
    I'm using minDualExtension constrain group. and the value type of the constraint group is DualValue, Dual1DTblValue, OneDDualArrayTblValue.
    Thanks again
