  3. Get Instance Terminal Coordinates in Schematic
  • Views 19352
KGh94
KGh94 over 8 years ago
I have added a MOSFET into a schematic and would like to locate the device terminals of the instance using SKILL code
geGetSelSet()~>instTerms~>term~>(coordinates?)
The only thing that shows any similarity to the coordinates is the bBox, but then the numbers in the bBox list don't reflect the actual coordinates of the terminals
Any hints would be appreciated.
Best regards,
Karam
  • mbracht
    mbracht over 8 years ago +1
    the below code returns the bBox coordinates you are looking for: inst=(car geGetSelSet()) (foreach mapcar term inst~>instTerms~>term (geTransformUserBBox (caar term~>pins~>figs)~>bBox inst~>transform…
  • mbracht
    HI Karam,
    geGetSelSet()~>instTerms~>term returns the terminals database objects in that instance's master cell - which is a cell view of type schematicSymbol.
    Other than that a terminal is a "logical thing" and nothing with a bounding box. Assuming that there is just one pin on the terminal and one pin figure on  that pin (which I think is a save assumption in a symbol) To get at the "selectable" pin you need to go like this...
    to get at the bounding box (with those corordinates being relative to the master cellview). So you'd still need to transform them with geTransformUserBBox(..) to make them realtive to your schematic
  • mbracht
          inst~>transform
  • KGh94
    KGh94 over 8 years ago in reply to mbracht
    Thanks a lot mbracht. Now I can derive the terminal coordinates with the help of your code! Slight smile
