  3. Extract Choices of Dynamic Property
  • Views 15125
KGh94
KGh94 over 8 years ago
I have an instance in a schematic that has two parameters: p_1 and p_2. Both p_1 and p_2 are set using a drop-down menu. I extract the choices using the CDF ID of the instance:
cdf_Id = cdfGetInstCDF(inst_Id)
cdf_Id~>p_1~>choices                   => ("1" "2" "3" "4" "5")
cdf_Id~>p_2~>choices                   => ("10" "20" "30" "40" "50")
Problem: In the schematic, p_2 changes every time p_1 is changed. This change is not reflected in the CDF of the instance.
Example: For p_1 = "1", p_2 is ("30" "40" "50"), for p_1 = "2", p_2 is ("10" "20" "30"), etc.
Is there a way to get the updated change using SKILL? Any hints would be appreciated.
Best regards,
Karam
  • KGh94
    KGh94 over 8 years ago in reply to mbracht +1
    Hello Max, Thank you for your reply. Turns out p_2 was a master parameter and the information I needed was in other parameters. Thanks Max! Best regards, Karam
  • mbracht
    mbracht over 8 years ago
    Hi Karam,
    I take it that p_2 is a derived CDF parameter that is implemented in terms of a CDF callback correct?
    The flipside of the coin of these CDF callbacks is that they are form callbacks meaning they are only triggered through the "Edit Properties" and the "Create Instance" form (when you place the instance) but not if you change p_1 in terms of a SKILL expression. So my first guess that you do not change p_2 in terms of the "Edit Properties" form do you?
    regards
    Max
  • KGh94
    Hello Max,
    Thanks Max!
    Best regards,
    Karam
