  3. Creating an ADE-L State, and Export as OCEAN, using SKI...
  • Views 19219
Creating an ADE-L State, and Export as OCEAN, using SKILL
KGh94
KGh94 over 8 years ago
I am trying to set up a complete ADE-L test-bench (including analysis, output expressions, and local variables) using SKILL. Then I would like to export it (also using SKILL) as an OCEAN file.
I have tried to do this for an ADE-XL test-bench and I was able to add a test, output expressions, and global variables (but was not successful with local variables or an analysis). Also I was not able to find a SKILL command to export the ADE-XL test-bench as an OCEAN file.
Going through the documentation of OCEAN, it was stated and creating an OCEAN file is done in two ways: using a text editor or using the GUI. Is all hope lost for what I'm trying to do?
Any pointers would be appreciated.
Best regards,
Karam
    Andrew Beckett over 8 years ago in reply to KGh94 +1
    Karam, This is much easier in ADE Assembler - there you have the "mae" (Maestro) functions which make it possible. You cannot set test (local) variables with axlPutVar, and you cannot set analyses…
    Hi Karam,
    Did you try just using File->Save Script in ADE XL? Or you could use this function:
    axlWriteOceanScriptLCV("blah.ocn" "opamp090" "full_diff_opamp" "adexl")
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for the quick reply. I would like to use SKILL, so File->Save Script is not an option for me.
    axlWriteOceanScriptLCV looks like what I need. Would it be possible to set an analysis and local variables for a test in ADE-XL?
    testId = axlPutTest(sdb "myTest" "ADE") axlPutVar(testId "VDD" "0:0.1:5")  ;adds a test
    axlPutVar(testId "VDD" "5")                                                ; does not add a local variable to testId
    axlPutAnalysis(testId 'dc)?                                                ; is this possible?
    Best regards,
    Karam
    Karam,
    You cannot set test (local) variables with axlPutVar, and you cannot set analyses using axlPutAnalysis (there's no such API). It has to be done with "asi" functions when doing this (which is why it's much easier with ADE Assembler).
    This article gives some clues as to how to do it with ADE XL: How to create adexl view for existing schematic with SKILL
  • KGh94
    Hello Andrew,
    Maestro looks perfect for setting up a test-bench. Can an OCEAN file be exported from maestro using axlWriteOceanScriptLCV?
    Best regards,
    Karam
    Hi Karam,
    Yes, you can use it there too (the same menu is available). However, better still is that you have the maeOpenSetup function and maeRunSimulation which means you can just load the setup from the maestro view and run that in batch. You can also change variables, change corners, enable and disable things, change other stuff with other mae functions.
    So the key benefit is that you don't need to dump out an OCEAN script which duplicates everything in the setup and then maintain that; you can directly run (in batch) the current contents of the maestro view, and tweak stuff as needed.
