  3. Regular Expression Matching Excluded Elements
  • Views 17626
KGh94
KGh94 over 8 years ago
I am working with the regular expressions in SKILL, and I'm trying to get the unmatched elements:
myList = '("te_mypattern_xt_1" "text_2" "text_3" "te_mypattern_xt_3" "te_mypattern_xt_3")
exclusionList = rexMatchList("mypattern" myList)
inclusionList = ??
In Python it is possible to use the negate operator "!mypattern", but I don't see something similar in the documentation. Any hints would be appreciated.
Best regards,
Karam
    Andrew Beckett over 8 years ago +1
    Hi Karam, The ancient "rex" functions certainly wouldn't support this, but looking at even the newer pcre (Perl-Compatible Regular Expressions) functions, they don't seem to have an inverted form. It…
    Hi Karam,
    The ancient "rex" functions certainly wouldn't support this, but looking at even the newer pcre (Perl-Compatible Regular Expressions) functions, they don't seem to have an inverted form. It's easy enough to write one though:
    procedure(CCFnegMatchList(pattern lst)
      let(((pat pcreCompile(pattern)))
        setof(elem lst !pcreExecute(pat elem))
    I did it this way rather than just using setof(elem lst !pcreMatchp(pattern elem)) because this way you're compiling the pattern just once, which makes it a more efficient.
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Thanks Andrew. What's the difference between pcreMatchp and rexMatchp?
    Best regards,
    Karam
    Andrew Beckett over 8 years ago in reply to KGh94
    Karam,
    pcreMatchp uses perl-compatible regular expressions - which are very powerful and quite extensive (see "man perlre"). The rexMatchp uses (very) basic regular expressions.
