  3. How to pass desVar using include file in ocean runs
  • Views 17416
BillPDB
BillPDB over 8 years ago
I have a testbench with tens of design variables. I have to create multiple ocean run files to test different functionality. To avoid confusion and keep run files simple I want to have only the variables necessary(couple of variables) in each run file and include a file containing all other design variables.
I tried to include this file a couple of ways and both didn't work. Is there another way?
  1. path( "<path_to_directory_containing_variables_file>" )
  2. definitionFile( "<path_to_directory_containing_variables_file>")
Thank you,
Prasad
    Hi Prasad,
    When you say "both didn't work", what exactly didn't work? What was the error? Just trying to understand what you'd tried and what didn't work.
    The path() function specifies a list of directories to search in, and the definitionFile is the name of an actual file to include; relative paths are found using the directories specified in path().
  • BillPDB
    BillPDB over 8 years ago in reply to Andrew Beckett
    Thank you for your response.
    Correcting the paths I used!
    1. path( "<absolute_path_to_directory_containing_variables_file>" )
    2. definitionFile( "<absolute_path_to_file_containing_variables>")
    Examples of entries in design_variables.scs file are below.
    simulator lang=spectre
    desVar(   "vdd"  1.2)
    desVar(   "vddio" 1.8)
    desVar(   "vVDD"  "vdd")
    In the first case, ocean gives out these errors..
    ERROR (SFE-1997): "input.scs" 5531: I78: parameter `Von': Cannot run the simulation because an unknown parameter `vVDD' has been specified in expression `vVDD'. Correct the expression and rerun the simulation.
    etc..
    In the second case, ocean run gives out these errors..
    ERROR (SFE-709): "absolute_path_to_file_containing_variables" 6: No master specified for instance `desVar'.
    ERROR (SFE-874): "absolute_path_to_file_containing_variables" 6: 10: Unexpected quoted string ""vdd". Expected end of file or end of line. Cannot run the simulation because of syntax error. Correct the error and rerun the simulation.
    etc...
    Please let me know if you need any other information.
    Thank you,
    Prasad
    Andrew Beckett over 8 years ago in reply to BillPDB
    Hi Prasad,
    OK, in that case it's hardly surprising it doesn't work. You've put desVar function calls (which are OCEAN/SKILL functions) into a spectre syntax file. You either need to use the approach you've used and put instead:
    parameters vdd=1.2 vddio=1.8 vVDD=vdd
    or simpler still, I'd create a file, commonVars.ocn which contains:
    desVar( "vdd" 1.2)
    and then rather than using path/definitionFile, simply in your OCEAN script use:
    load("/path/to/commonVars.ocn")
    at the appropriate point in your OCEAN script (i.e. after the design() and before the run() somewhere).
    If you prefer the syntax, you can use:
    include("/path/to/commonVars.ocn")
