  3. Finding and counting duplicates in a list
  • Replies 7
  • Subscribers 150
  • Views 21279
LakshmanQual
LakshmanQual over 8 years ago
Hi Team,
If my list had ("a" "b" "c" "a" "d" "f" "a" "c" "b"), then it should give a=3,b=2,c=2. No need to give 'd' and 'f'.
How to code in Cadence SKILL to find the duplicates count?
    Andrew Beckett over 8 years ago in reply to Marcel Preda +1
    Marcel Preda said: foreach( e myTable~>? if( myTable[e] == 1 then remove(e myTable) ) Marcel - a small change - you don't really need to do myTable->? here because if you do a foreach over a table the…
  • mbracht
    mbracht over 8 years ago
    Use a table:
    ll='("a" "b" "c" "a" "d" "f" "a" "c" "b")
    llUniq = nil
    tbl=(makeTable 'tbl nil)
    (foreach el ll
       (unless tbl[el]
          tbl[el] = t
          llUniq = (append llUniq (list el))
    Max
  • Marcel Preda
    Marcel Preda over 8 years ago
    procedure( MpFindDuplicated( lx )
    let( (myTable)
    myTable = makeTable("myTable" 0)
    foreach( e lx
    myTable[e] = 1 + myTable[e]
    remove(e myTable)
    ;; return value
    myTable
    myList = list("a" "b" "c" "a" "d" "f" "a" "c" "b")
    duplicated = MpFindDuplicated(myList)
    printf("%L\n" duplicated~>??)
    Output will be something like : ("a" 3 "b" 2 "c" 2)
    remove(e myTable)
    Marcel - a small change - you don't really need to do myTable->? here because if you do a foreach over a table the loop variable will be set to each key anyway. So you can just do:
    foreach(e myTable
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Andrew Beckett
    The code is not working. As its throwing error for make table command. Showing "undefined function: myTable"
    Andrew Beckett over 8 years ago in reply to LakshmanQual
    You must have made a typo somewhere - the code above that Marcel gives (or my suggested modification) can't cause that error.
    My guess is that somewhere  you have (myTable) or myTable() - with parentheses around the name (not sure where you've done this). Perhaps you can paste the code which is failing and the exact error you're getting?
  • Marcel Preda
    Marcel Preda over 8 years ago in reply to LakshmanQual
    Please double check that you use square brackets where it is needed. E.g. myTable[e] , and not myTable(e)
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Marcel Preda
    Hi Marcel and Andrew, Thanks for the script. Its working fine.
