  3. How to get instance mode
  • Replies 16
  • Views 22526
psill000
psill000 over 8 years ago
How do I get the mode of an instance in layout.
I know the cell is editable but when I try instDb~>master~>mode or instDb~>master~>mode~>cellView I get "r".
Paul
  • mbracht
    mbracht over 8 years ago
    Hi Paul,
    I'am not sure whether it makes sense to talk about the "mode of an instance". An instance points to a master cell view and the mode of that master cell view depends from how you open it - in "r", "w" or "a"mode.
    In other words - I  think the mode is an attribute of a cell view in memory only. You may open a cell view in  in "a" mode and in one design editor and in "r" mode in another one.
    Moreover - the SKILL expression 'instDb~>master~>mode~>cellView' will throw an error because 'instDb~>master~>mode' returns a string to which you cannot apply a squiggle operator.
    Or maybe I just didn't get your question right...
    Max
    Andrew Beckett over 8 years ago in reply to mbracht
    Max, Paul,
    If you open the cellView in "r" mode in one window and "a" mode in another, it will be editable in both windows because the mode is per cellView, not per window (and it picks the highest mode).
    I did wonder whether the instances were instances of pcells, in which case the master would have a different mode than the superMaster, but then the mode of the master (subMaster) is "s" regardless of the mode of the pcell superMaster.
    Note the mode is not whether it can be edited or not, it's whether it is open for edit or not. I can only assume the instance you have is a different cellView than you think it is - because the mode cannot be two different things for the same cellView.
  • mbracht
    mbracht over 8 years ago in reply to Andrew Beckett
    Thanks for the clarification. What is really surprising for me is that the mode is not per window. I mean sometimes when you try to open a design you get a message that this cell view can be opened in read mode only (I was always assumimg because somebody else had opened it in write mode)...or maybe this is controlled through clsbd is it?
    Max
    Hi Max,
    Locking only plays a part when trying to open it for edit in two different virtuoso sessions (two different processes). clsbd is only used for stranded lock recovery - this is where it looks at the details in the lock file (which says which process id on which machine has the lock), and then the locking system asks clsbd on that machine to check if that process is still running or not. If it's not, then the lock file can be removed and then the open for edit can proceed. If there's no response from the request to clsbd (maybe clsbd isn't running, or the machine is unreachable) it errs on the side of caution and retains the lock. Obviously if it says that the process is running still, then the lock is denied too.
  • mbracht
    That pretty much matches my understanding of how clsbd works - I was just getting confused because of that mode attribute. And quite honestly I still don't quite get it why the mode is an attribute of a cell view. I mean in the end attributes get saved to the layout.oa file don't they? Why would you store this information on the hard disk? Or is the mode an attribute of the cell view in memory only?
    Sorry for keeping you so busy...
    Max
    Max, the mode is not saved to disk (that wouldn't make any sense). It's an attribute of the in-memory cellView representation to say which mode it's currently open in. The in-memory representation of various db objects contain additional data that only make sense in memory and are not saved persistently to disk.
  • mbracht
    Thanks - no more questions Slight smile
  • psill000
    psill000 over 8 years ago in reply to Andrew Beckett
    Sorry I did not describe the circumstance better. I have a script to move objects into an instance. The object and the instance are in the same cellview and move the object into a lower level. I want to test if the instance is in read or edit mode. I opened the instance for edit and I still got a "r" when I check the mode, instDb~>master~>mode.
    Was there another way to test if the instance editable or is there something I am missing. ( Its not a pcell )
    Paul
  • mbracht
    mbracht over 8 years ago in reply to psill000
    Paul,
    May we see the script.
    Max
  • psill000
    psill000 over 8 years ago in reply to mbracht
    procedure(instMode(inst)
    let( (mode)
    if(equal(inst~>master~>mode "r") then
    printf("Instance %s is in read only mode.\n" inst~>cellName)
    else mode = t)
    mode
    ); end of let
    ); end of instMode
