  3. how to plot waveforms after OceanXL script finished sweeping...
  • Views 15101
how to plot waveforms after OceanXL script finished sweeping corners
DavidLou
DavidLou over 8 years ago
Hello exports,
we setup corner sweeping tests from ADE-XL and saved as OceanXL script. It works well except the script doesn't bring up the result waveforms we want to see. what kind command or script could help to plot the waveforms up at the end of OceanXL script?
P.S., from ADE-XL, once I set "Setup Plotting Option" -> "Plotting Option" to "Auto", then it'll bring up all plotted signals up in waveform. But that isn't reflected in saved OceanXL script which is the reason I'm asking here.
thanks,
David
  • DavidLou
    A bit follow up from what I tried.
    from Chris's code, I'm able to plot from Ocean script but that need forehead knowledge where the result will be saved and the names of different level of them. I'm hoping something like axlReadHistoryResDB as from Andrew's code might help me to access all the results for various corners. any possible?
    thanks,
    David
