  3. Running a SKILL script from Command Line
  • Replies 10
  • Views 37111
KGh94
KGh94 over 8 years ago
I have a skill file that I would like to run in command line. I am looking for the fasting execution time, so "virtuoso -nograph" would be my last resort.
What would be the best way to run a script containing db* and dd* functions?
Best regards,
Karam
    Andrew Beckett over 8 years ago +2
    Hi Karam, dbAccess -load yourCode.il Andrew.
    Hi Karam,
    • Vote Up +2 Vote Down
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Thanks Andrew. I read in a thread that for using sch* commands "virtuoso -nograph" would be unavoidable. Is that true? Is it also the case for mae* commands?
    Best regards,
    Karam
    Andrew Beckett over 8 years ago in reply to KGh94
    Hi Karam,
    Yes and yes. dbAccess only contains the low level database, tech, CDF and SKILL functions - no application layer capabilities.
  • KGh94
    Hello Andrew,
    Thanks for the clarification. Is there a db* alternative for schCheck( myCellView ), for schematic checks?
    Best regards,
    Karam
    Hi Karam,
    No, not unless you construct all the connectivity yourself in the code too (which is potentially quite difficult). It rather depends on what you're doing as to how hard this would be. Note you could make the virtuoso startup quicker by using "virtuoso -nocdsinit -nograph -restore code.il"
  • KGh94
    Hello Andrew,
    Thanks for the tip. What is the added value from -restore? The -help line looks quite vague to me "Specifies the session file to restore". Does restore run the SKILL file?
    Best regards,
    Karam
    Hi Karam,
    It's like doing load("code.il") after virtuoso has started. So yes, it runs the code in the file.
    It's different from doing -replay (-replay strictly expects a replay file although it does work without the extra tags at the beginning of each line). Using -restore however tends not to have issues with UI code getting a bit confused - so I always tend to use -restore.
  • tweeksii
    tweeksii over 8 years ago in reply to Andrew Beckett
    I'd been wondering about that!  Glad I stumbled on this thread. :)
  • tweeksii
    tweeksii over 8 years ago in reply to tweeksii
    I had been using -nographE to work around UI code problems, but I will try -restore, which sounds like it's more lightweight than -nographE.
    Andrew Beckett over 8 years ago in reply to tweeksii
    They're not really the same thing. All that -nographE does is not produce a CIW window - it still requires a connection to an X server. Whereas -nograph uses a null X display (implemented these days with a vnc server) to swallow all the graphics events (but of course means that you can't click on any forms or dialog boxes).
    Sometimes using -replay with a SKILL file (as opposed to a replay file) can have unexpected blocking behaviour - which is different than what you might get if you'd used load() at the prompt (or in the CIW if graphical). -restore is really just like using load after initialisation has finished.
