  3. How to add minimize & maximize button to a form using s...
  • Views 2920
How to add minimize & maximize button to a form using skill
skilluser132
skilluser132 over 8 years ago
Hi ,
How to add minimize & maximize button to a form using skill?  By default , it has only close button.
Thank You.
    You can't. The minimize/maximize buttons are something that is under the control of the window manager and not something an application programmatically controls. For some window managers (such as KDE), these appear for both normal windows and transient windows (e.g. forms), but for other window managers they only appear for normal windows.
    If you have a window manager that doesn't add minimize/maximize buttons on transient windows and doesn't give you the option to do so, then the only option is a form window - this is where you use hiCreateWindow and associate that with a form (this is covered in the documentation).
  • skilluser132
    skilluser132 over 8 years ago in reply to Andrew Beckett
    Thanks Andrew, for your inputs.  I will try it & get back.
    Regards.
