  3. Merging the list of lists
  • Views 18978
LakshmanQual
LakshmanQual over 8 years ago
Hi Team,
I had a list of lists with different lengths as llist=(("a" "b" "c") ("d" "e") ("f" "g" "h")("i" "j")).
I want to merge/flattern them as a list=("a" "b" "c" "d" "e" "f" "g" "h" "i" "j")
Is there any command to flattern the list of lists??
  • mbracht
    mbracht over 8 years ago
    You can use the mapcan function to achieve this:
    (mapcan (lambda (el) (if (listp el) el (list el))) '(("a" "b" "c") ("d" "e") ("f" "g" "h")("i" "j")))
    Max
    Andrew Beckett over 8 years ago in reply to mbracht
    Same question has come up before - here's my earlier answer on this.
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Andrew Beckett
    Hi Andrew, Max
    Thanks for the reply. the codes are working fine.
