  3. SKILL command to access the database ID of a marknet result...
  • Subscribers 148
  • Views 15454
SKILL command to access the database ID of a marknet result in layout?
Marben
Marben over 8 years ago
Hi All,
What is the SKILL command to access the database ID of a marknet result in layout?
Because I want to get the width of all the paths, rectangles, vias that are
being marked by marknet command in vxl.
Best regards,
Marben
  • skillUser
    skillUser over 8 years ago
    Hi Marben,
    I don't think you can directly, but you can save the market result to another cellview and then you can process the shapes in that cellview.
    Hope it helps.
    Lawrence.
  • Marben
    Marben over 8 years ago in reply to skillUser
    Hi Lawrence,
    Thank you very much for replying.
    Best regards,
    Marben
