  3. How to give net name while creating path from skill?
  • Views 19486
Leonardo Vinci
Leonardo Vinci over 8 years ago
Hi, i am using dbCreatePath() function to create a path, but i dont know how to attach the net name with that path. Any suggestions? Any other function through which we can give the net name to the created path?
LEO
    Use dbMakeNet to create the net, and dbAddFigToNet to add the newly created path to the net.
  • mbracht
    mbracht over 8 years ago
    Hi LEO,
    You could use rodCreatePath() (which will create your path as a ROD object):
    (rodCreatePath ?cvId <cv> ?layer <layerName> ?pts <pointsList> ?netName <netName>)
    Max
  • voace
    voace over 7 years ago in reply to Andrew Beckett
    Hi, I am giving name to a route using below script
    netId=dbMakeNet(geGetEditCellView() "VSS")
    s=geGetSelSet()
    dbAddFigToNet(car(s) netId)
    But i am getting an error *WARNING* (DB-270000): dbAddFigToNet: Figures that belong to a route cannot be added to a net.
    nil
    Kindly help me out
    Andrew Beckett over 7 years ago in reply to voace
    I believe the only solution here is to delete the route object:
    fig=car(s)
    when(fig~>route
      dbDeleteObject(fig~>route)
    Then you can add the figure to the net.
