  3. Using Callbacks
  • Views 19760
Using Callbacks
KGh94
KGh94 over 8 years ago
I have seen callbacks in action in some scripts but never grasped the concept of how callbacks really work.
An example is given:
;; Post-simulation callback. Called after each run.
define( RunFinishedCallback(session runID)
    printf("Run ID %L has finished" runID)
; Run simulations
history1 = maeRunSimulation(?session session1 ?callback "RunFinishedCallback")
How are session and runID passed to the RunFinishedCallback function? and what passes them?
Best regards,
Karam
    Andrew Beckett over 8 years ago +1
    Hi Karam, The term "callback" is used for a number of different situations, but in general it's a means of having a function that gets called when some kind of event occurs. In this case it's called…
    Hi Karam,
    The term "callback" is used for a number of different situations, but in general it's a means of having a function that gets called when some kind of event occurs. In this case it's called when the simulation finishes. In some cases the callback is a complete SKILL expression which is just evaluated using evalstring, but in others you provide the name of the function to call (or in an increasing number of cases, you can also provide the function object which is beneficial when using SKILL++). In this case you're doing just that - providing the name of the function to call.
    The documentation for the function which triggers the callback should explain how the callback should be written. It does in this case too (via the examples), although it doesn't do a great job of explaining what the arguments mean. What happens in the case when you supply just a function name is that it automatically calls that function with some arguments to supply information about the context under which the callback was triggered - in this case the maestro session ID and also the run ID (to indicate which run completed). It's the maeRunSimulation function (or rather the event at the end of the simulation) which will call the callback and supply the arguments.
    Hope that helps,
