  3. Need to transform co-ordinates to current hierarchy
  • Views 15901
RAGHU2634
RAGHU2634 over 8 years ago
Is there any way to access the shapes in lower hierarchies and transform them to current hierarchy using SKILL
Raghu
    Andrew Beckett over 8 years ago +1
    Hi Raghu, Yes. I suggest you search in the forums for dbConcatTransform - there are a number of threads asking similar questions. You can use the inst~>transform as the argument on each level of hierarchy…
    Hi Raghu,
    Yes. I suggest you search in the forums for dbConcatTransform - there are a number of threads asking similar questions. You can use the inst~>transform as the argument on each level of hierarchy, and concatenate the transformation at each level, and then use dbTransformPoint, dbTransformPointList or dbTransformBBox to do the transformation.
  • Marben
    Marben over 8 years ago
    Hi Raghu,
    Something like this.
     cb = centerBox(css()~>bBox) ; shape's centerbox in lower hierarchies.
     inst_transform = css()~>transform ;instance in current hierarchy
     location = dbTransformPoint(cb inst_transform) ;location of shape in lower hierachy to the current hierarchy.
    Hope this help.
    Best regards,
    Marben
