  3. creating pin and direction table for schematic
  • Views 19374
LakshmanQual
LakshmanQual over 8 years ago
I am trying to create a list of lists for pin and corresponding direction using "Pin_And_Dir=foreach(mapcar term cv~>terminals list(term~>name term~>direction)". Its crating as below
pin1 input
pin2 input
pin3<0:1> input
pin4<3:0> output
The problem is when there is a bus for some pins. But i want them separated as below:
pin1 input
pin2 input
pin3<0> input
pin3<1> input
pin4<3> output
pin4<2> output
I tried to use dbProduceMemName for pin names. But its expanding only pin names but direction is not replicating to them.
Could you please help on this to make pins and directions  as list of lists or table format?
  • Marben
    Marben over 8 years ago
    Hi LakshmanQual,
    Something like these:
    cv~>terminals~>net~>signames
    Hope this help.
    Best regards,
    Marben
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Marben
    With this we can get pin names separated which can be done by "dbProduceMemName(bus)". But i was not able to get pin direction if its separated from bus.
    Andrew Beckett over 8 years ago in reply to LakshmanQual
    Pin_And_Dir=foreach(mapcan term cv~>terminals foreach(mapcar termMember dbProduceMemName(term~>name) list(termMember term~>direction)))
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Andrew Beckett
    Hi Andrew, Its working fine.
    Could you please help me in making them as direct list of lists. They are coming as (((pin1 dir)) ((pin2 dir)) ((pin3<0> dir) (pin3<1> dir)) ((pin4<0> dir) (pin4<1> dir)))
    But i want them as (pin1 dir) (pin2 dir) (pin3<0> dir) (pin3<1> dir) (pin4<0> dir)..
    I want them to compare schematic and layout pins, corresponding directions..
    You must have mistyped what I posted (I assume you didn't cut and paste it). The first foreach should be a mapcan and I think you must have used mapcar instead (the inner loop is using mapcar, however). My code outputs:
     ("a" "input")
     ("b<3>" "output")
     ("b<2>" "output")
     ("b<1>" "output")
     ("b<0>" "output")
     ("c<5>" "inputOutput")
     ("c<4>" "inputOutput")
     ("c<3>" "inputOutput")
     ("c<2>" "inputOutput")
     ("c<1>" "inputOutput")
     ("c<0>" "inputOutput")
  • LakshmanQual
    I was mistyped the code which you mentioned. Its working good now. Thanks!!
