  3. Unable to delete cell because of maestro view
  • Views 21293
KGh94
KGh94 over 8 years ago
I created a schematic and a maestro test bench to simulate my schematic. After finishing my simulations and extracting my results, I deleted the cell (right-click -> delete)
The cell views are deleted but the cell remains, and I get the following messages:
*WARNING* Window 1 does not exist
*WARNING* ddDeleteObj: Failed to unlink $PWD/myLib/myCell/maestro/results/maestro/.nfs0000000000f7efb90000133d - Device or resource busy
*WARNING* ddDeleteObj: Failed to remove directory $PWD/myLib/myCell/maestro/results - Directory not empty
*WARNING* ddDeleteObj: Failed to remove directory $PWD/myLib/myCell/maestro - Directory not empty
*WARNING* ddGetOAObject: Couldn't find an OA cellview object for view 'maestro' in lib 'myLib', cell 'myCell'
*WARNING* ddDeleteObj: Failed to remove directory $PWD/myLib/myCell - Directory not empty
The problem is that I can no longer open a maestro cell view in that cell (but I can create one). I can't do "rm -r" to the directory either.
Any help would be highly appreciated.
Best regards,
Karam
    Hi Karam,
    Was the schematic and Explorer or Assembler view still open in a window?
    Which subversion are you using (Help->About in any of the windows will tell you)?
  • mbracht
    mbracht over 8 years ago
    Hi Karam,
    These .nfs<whatever> files occur on nfs mounted filesystems when some process tries to delete a file while another process is still holding a filedescriptor for that file's inode. You might try
    % lsof $PWD/myLib/myCell/maestro/results/maestro/.nfs0000000000f7efb90000133d
    to find that process.
    Max
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    I had the assembler view open in a virtuoso window, and I was editing the view in a virtuoso -nograph. I closed the virtuoso -nograph application and closed the assembler view in virtuoso as well. I tried deleting and got the error. I had to exit virtuoso to be able to delete the maestro view
    Best regards,
    Karam
  • KGh94
    KGh94 over 8 years ago in reply to mbracht
    Hello Max,
    Thanks for the command to find the process. I will try it the next time this happens
    Best regards,
    Karam
  • KGh94
    Hello Max,
    So it happened again, virtuoso is locking it even though I closed the assembler view
    Andrew Beckett
    Best regards,
    Karam
    Andrew Beckett over 8 years ago in reply to KGh94
    Karam,
    Four questions:
    1. Which subversion of Virtuoso are you using? (we asked earlier, but you didn't say)
    2. What is the contents of the .nfs file you have left in the view?
    3. Were you creating this view with the mae SKILL functions? I'm wondering whether you have an open session that way as well as interactively
    4. Does lsof indicate virtuoso as the owning process for the leftover files?
