  3. select block view in ocean script
  • Views 17776
DavidLou
DavidLou over 8 years ago
hello exports,
think I have behavior models developed for my design. then I want to swap one block/cell at a time by real transistor level block/cell with all rest behavioral models. How can I pick such transistor/behavioral view in ocean script so that I can run these tests in a batch?
I know I can use Hierarchy Editor to create many config to use different views, but that could be very messy once I have so many configs.
thanks a lot,
David
  • DavidLou
    just to clarify what I'm looking for. I'd like to have the equivalent SKILL/OCEAN script to define what Hierarchy Editor gui does.
    Andrew Beckett over 8 years ago in reply to DavidLou
    This could be done with the hdb APIs if you really want to do it with an OCEAN script. It could also be done with CONFIG view variables in ADE XL (and probably simpler in Assembler if you then want to create a simple script to batch run the simulations).
    The hdb APIs would involve you using:
    hdbOpen - to open the config
    hdbSetObjBindRule - to change the binding rule for a cell
    hdbSave
    hdbClose
    This could also be done by having a config and then using CONFIG view variables (use right mouse button menu over the global variables in ADE XL or Assembler to add the variable) - then you could have one variable for each cell you wish to switch, and potentially arrange all the combinations via corners (say).
  • DavidLou
    DavidLou over 8 years ago in reply to Andrew Beckett
    thanks Andrew,
    I assume hdb APIs would physically require a config existing ahead and the API would physically change the file after each run, right? anyway, I'll try that out.
    thanks,
    David
    Hi David,
    Not necessarily. You can create a config from scratch using hdbOpen but you'd also need to tell it the top level cellView and the global switch and stop lists (via the appropriate APIs). It's not that difficult though.
  • DavidLou
    hi Andrew,
    a following up question regarding this (sorry to resume an old thread here), I can see the expand.cfg config file is pure text based configuration, so can we just put those config text or something similar into Ocean script so that the Ocean script is self-sustaining w/o creating a physical config view?
    thanks,
    David
    Hi David,
    There's no support for creating the config view from a textual representation of the expand.cfg contents. Yes, it's text and yes, it's fairly intuitive, but it's not documented and so may change without any notice. Therefore you should only ever create the config view with the SKILL API or using the hierarchy editor.
