  3. Cleaning up a layout view
  • Replies 7
  • Subscribers 148
  • Views 21753
RK56
RK56 over 8 years ago
I looking for a reliable way to clean up the layout for that following needs
1. Delete orphaned nets => Remove nets that are not attached to any physical shape
2. Delete orphaned terminals =>Remove terminals that are obsolete (not connected to any physical shape, mostly the old name of a renamed terminal)
3. Fix cell extent boundary => Sometimes some ZoomToFit  fits to a boundary which is much zoomed out than the actual layout. Which is mostly because of steiners or some unknown object (in non streamout layer) presence.
The following is the current solution I have but not sure if it is reliable
1. mapcar('dbDeleteObject setoff(x cv~>nets !x~>pin))
3. mapcar('dbDeleteObject cv~>steiners)
-Ramakrishnan
  • mbracht
    mbracht over 8 years ago
    Hi Ramakrishnan,
    I don't think the fact that a net doesn't  have a pin (net~>pin) necessarily means there is no shape on that net - so I'd rather go like that:
    (mapcar 'dbDeleteObject (setof net cv~>nets !(member net~>name (setof shape cv~>shapes shape~>net)~>net~>name)))
    Max
  • mbracht
    I forgot about the terminals...
    (foreach term (setof term cv~>terminals (not (caar term~>pins~>figs))) (dbDeleteObject term))
    not sure about the extent boundary though...sorry
    Max
  • RK56
    RK56 over 8 years ago in reply to mbracht
    Max.
    Thank you. Your solution is more reliable than mine. I wonder why Cadence does not clean up these by default.
    -Ramakrishnan
    Andrew Beckett over 8 years ago in reply to RK56
    Hi Ramakrishnan,
    It does clean up by default (certainly VLS XL). One thing to remember however is that deleting nets which don't have any figures means you may be deleting the information that VLS XL uses to know what needs to be connected - there may be logical connections in the database (e.g. connections of the nets to instTerms) but no physical information yet, and if you remove the logical information then VLS XL won't know that a net needs connecting.
    Similarly terminals should get removed if the pins are removed - provided that the terminal is not supposed to be in the database (VLS XL also would keep the terminals there if the pin has not been placed yet).
    So be very careful about doing this kind of "clean up". Yes, steiners do seem to go a bit awry at times (although this seems to be better nowadays than in the past) which causes the "fit" not to work properly, but be cautious about removing connectivity information.
    Oh, and Max's code won't be very efficient for large designs because it's repeatedly building a list of the net names for all shapes as it iterates over each net. You could (I think) achieve the same thing with:
    mapcar('dbDeleteObject setof(net cv~>nets !(net~>pins || net~>figs)))
    If you wanted to ensure that logically connected nets were also preserved, you could do:
    mapcar('dbDeleteObject setof(net cv~>nets !(net~>instTerms || net~>term || net~>figs)))
    However, as I said above, I'd be cautious about doing that (it's quite possible that this also isn't covering every reasonable case where the connectivity should be preserved - I didn't think about it very hard).
  • RK56
    RK56 over 8 years ago in reply to Andrew Beckett
    Somehow I see the cleaning does not happen by default.  We have some poorly written scripts which fall prey for these stray nets and terminals.
    I will consider the above line of script. Wondering why you dropped "nets~>pin" from the condition. Is that "net~>term" is inclusive of "net~>pin"?
    Thanks.
    -Ramakrishnan
    Ramakrishnan,
    If you really have some nets which aren't removed which should be, you should contact customer support.
    I removed the net~>pins because if there are any net~>pins then there would also be net~>term for the terminal associated with that pin. However, it is possible that you could have a terminal without a pin (if the pin has not been gen from sourced yet, or has been deleted temporarily). So checking for nets with a terminal as opposed to just those with pins is a safer check.
  • RK56
    Ok. Thank you.
