  3. Creating Corners in maestro using SKILL
  • Views 17511
KGh94
KGh94 over 8 years ago
I was looking in the maestro documentation for a command to create a corner in my test. I couldn't find creation, but rather only enabling/disabling:
maeSetSetup(?corners '("C0" "C1") ?variables '("VDD" "IREF")?enabled nil)
; Disables the C0 and C1 corners, and the VDD and IREF global variables
Is there a way to create a corner in maestro using SKILL?
Best regards,
Karam
    Hi Karam,
    You have to use the axl functions to create the corners; there's no specific "mae" functions to do it (there's the ability to load the corners from a file, but not to define them from scratch). It's perfectly OK to use the axl functions to do this though.
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for the confirmation. I noticed that it's not possible to disable nominal corner in maestro:
    ; check active corners
    maeGetSetup(?typeName "corners" ?enabled t)    => ("nominal" "myCorner")
    ; disable nominal corner
    maeSetSetup(?corners '("nominal") ?enabled nil)
    I get the message:
    WARNING (ASSEMBLER-8047): Failed to disabled corner nominal because it does not exist in the currently active setup. Specify a valid corner name. Use maeGetSetup(?corners) to get list of corners available in this session.
    I would also point out that the underlined command is incorrect and would return an error..
    Is there a work-around for disabling the nominal corner?
    Best regards,
    Karam
    Andrew Beckett over 8 years ago in reply to KGh94
    Hi Karam,
    It's a limitation of the API, and is covered by CCR 1920347. Hopefully we can fix this before too long as well.
    The workaround is to use:
    sess=maeOpenSetup(...) ; make sure you record the session when you start with maeOpenSetup
    ; could also use sess=axlGetWindowSession() if running interactively
    sdb=axlGetMainSetupDB(sess)
    axlSetNominalCornerEnabled(sdb 0)
    This will disable it. Set the second argument to 1 to enable the nominal corner.
