  3. ADE-L/Spectre Sensitivity Analysis Form - is it possible...
  • Views 2553
ADE-L/Spectre Sensitivity Analysis Form - is it possible to change the list of outputs using Skill?
Marcel Preda
Marcel Preda over 8 years ago
 Hi *,
Is there an API in skill to change list of the outputs for 'sens analysis, to have it immediately visible in the session form?
I have the list of outputs stored in some external file and I want to add them in some already open session .
I have access to the sessionId object, virtuoso  v6.1.5+
Thank you,
Marcel
    Hi Marcel,
    No. The sens analysis has a layer of indirection between what is shown in the UI and what is used for netlisting (which is the 'net and 'term analysis field slot, e.g. using asiGetAnalysisFieldVal) - keeping them in sync requires using a private API (as far as I know). The instances part was broken too even if you saved to and from a state, or used ADE XL. That was fixed in IC617 ISR10 - but don't think that's what you're asking for here.
