  3. Comparing list of lists
  • Views 17466
LakshmanQual
LakshmanQual over 8 years ago
Hi Team,
I had a list of lists like ll1=(("a" "3") ("b" "2") ("c" "4") ("d" "2") ("f" "1"))
ll2= (("d" "3") ("a" "3") ("g" "1") ("b" "3") ("f" "1") ("y" 2") ("z" "6"))
while comparing those list of lists for the availability of characters and numbers, i am not able to use break statements in foreach loops to break corresponding loop. Could you please help me in my code??
foreach(char1 ll1
    value=0
   foreach(char2 ll2
     if(car(char1)==car(char2) && cdr(char1)==cdr(char2) then
         value=1)         ;I dont have any breaks statements in SKILL to use once the character is available and break the loop here
    if(car(char1)==car(char2) && cdr(char1)!=cdr(char2) then
         value=2)           ;I dont have any breaks statements in SKILL to use once the character is available and break the loop here
    if(car(char1) != car(char2) then
) ;inner foreach loop
if(value==1 then   printf("character is available and repetitions matched for %L\n" car(char1))
   else
       if(value ==2 then printf("character is available but repetitions mismatched for %L\n" car(char1))
        else
           if(value == 3 then printf("character not available %L\n" car(char1)))))
)   ;outer foreach loop
    I don't think your logic is quite right (even if you had the break()) because the inner loop would always break on the first element of the inner loop. You can implement a "break" using prog and return (although personally I dislike this approach, as it offends my ideas about structured programming). I think you want:
    foreach(char1 ll1
       value=3
       prog(()
         foreach(char2 ll2
               value=1
               return()
               value=2
               return()
      if(value==1 then
      else
        if(value ==2 then
          else
             if(value == 3 then
    I'd probably write it like this instead, which avoids the use return (which is a glorified goto and is hard to follow the code because you have code that sometimes jumps out of the middle of a loop):
    foreach(char1 ll1
      value=3
      forall(char2 ll2
        cond(
             value=1
             nil
             value=2
             nil
          (t
             t
       ) ;inner forall loop
      case(value
        (1
        (2
        (3
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Andrew Beckett
    hi Andrew, Thanks for the corrections. Its working as i desire.
