  3. pin information
  • Replies 11
  • Views 21823
pin information
LakshmanQual
LakshmanQual over 8 years ago
hi Team,
I had a list with some pins of layout.
I need to find those pin info of layout(only corresponding hierarchy and no need of lower instances) of the list like pin coordinates and pin layer. I tried using dbFindTermByName but its not taking names of the lists as input.
In those some pins might be repeated. So need co ordinates of all the locations.
Could you please help me in coding this?
pin1     layer    co-ordinates
pin2    layer     co-ordiantes
    You'll need to expand a bit more. What precisely does your input look like? "A list with some pins of layout" doesn't really explain it very well...
    If it was terminal names:
    termNameList=list("inm" "inp" "outm" "outp" "VDD" "VSS")
    pinInfoList=nil
    foreach(termName termNameList
      term=dbFindTermByName(cvId termName)
      foreach(pin term~>pins
        foreach(pinFig pin~>figs
          pinInfoList=cons(list(termName pinFig~>layerName centerBox(pinFig~>bBox)) pinInfoList)
    At the end pinInfoList would be (maybe) what you want. However, I may have completely misinterpreted your question, since it wasn't clear.
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Andrew Beckett
    By doing some other operations, i had a list of pins which are in layout.( A kind of sub-set of all layout pins of that level).
    If cv=geGetWindowCellView() and myList = ("inp" "inm" "out" "VSS" "VDD")
    Is cvId = cv~>view or cv~>viewName ? Both are throwing error. Its showing arg#1 should be a database object (type templete="dt") for "dbFindTermByName"
    Andrew Beckett over 8 years ago in reply to LakshmanQual
    cvId=cv  ; (i.e. cvId=geGetEditCellView() or geGetWindowCellView())
    The error (and documentation for dbFindTermByName) should have made that pretty clear - even the quick help in cdsFinder:
    dbFindTermByName(
    d_cellView
    t_name
    => d_term / nil
    Finds a terminal in a cellview.
    If you have a list of pins, are these the pin objects, or the pin figures? If it was pin figures, then you'd just do:
    foreach(mapcar pinFig listOfPinFIgs list(pinFig~>pin~>term~>name pinFig~>layerName centerBox(pinFig~>bBox)))
    As I said, asking a clear question is pretty important here - otherwise we have to guess what your data  looks like.
  • Marben
    Marben over 8 years ago
    Hi LakshmanQual,
    Here is my script to find pins in the layout.
    I hope this help.
    Best regards,
    Marben
    Purpose      : To get pins location in the layout.
    How to run   : 1. load("/home/eda/SKILL_VXL/pins_coordinates.il")
                   2. pins_coordinates()
    Date created : July 10, 2018
    Author       : Marben F. Orallo
    procedure(pins_coordinates()
     csh("touch ./coordinates_pins.txt")
     outPort = outfile("./coordinates_pins.txt")
     ctr = 0
     cv = geGetEditCellView()
     pins = cv~>terminals~>pins
     pins_flatten = CCSflattenList(pins)
     pin_id = setof(x pins_flatten x~>name)
     fprintf(outPort "\n Pins location in the layout. \n")
     foreach( pin_id pin_id
      loc = centerBox(pin_id~>fig~>bBox)
      ;printf("\n Connection found, connection is not yet finish. %L %L" pin_id~>name loc)
      fprintf(outPort "\n %L %L %L" pin_id~>name pin_id~>fig~>lpp loc)
      ctr = ctr + 1
     ) ;for
     fprintf(outPort "\n\n ctr = %d" ctr)
    close( outPort)
    sleep(1)
    system("gedit ./coordinates_pins.txt &")
    );proc
    procedure(CCSflattenList(l)
      if(listp(l) mapcan('CCSflattenList l) list(l))
  • LakshmanQual
    LakshmanQual over 8 years ago in reply to Marben
    Hi   Marben Orallo and Andrew,
    I already had a list which i got them with some operations in the skill code as pins_conflicts= ("inp" "inm" "out" "vdd" "vss").
    For Eg:
    pins = cv~>terminals~>pins~>name = ("in1" "in2" "inp" "inm" "vdda" "vssa" "out" "vdd" "vss" "gnd" "out2" "out3" "out4" "out5" )
    after some operations i got few of the conflict pins from the above as
    I want to find the pins which are in "pins_conflicts" list from my layout and find co-ordinates and pin layers. I need to code in the same skill code.
    In the following code
    foreach( pin pins_conflicts
    printf("%L" "%L" "%L\n" pin pin~>fig~>lpp centerBox(pin~>fig~>bBox))
     i cant apply pin~>bBox or pin~>fig~>bBox as already 'pin' is in text format and not the 'hexcode'
    Could you please consider the above criteria and help in coding as mentioned above.
    Andrew, Sorry for not asking the question clearly.
  • Marben
    Marben over 8 years ago in reply to LakshmanQual
    Hi LakshmanQual,
    Something like this, is what you want ?
    procedure( pins()
     pins = list("in1" "in2" "inp" "inm" "vdda" "vssa" "out" "vdd" "vss" "gnd" "out2" "out3" "out4" "out5" )
     pins_conflicts= list("inp" "inm" "out" "vdd" "vss")
     foreach(pin pins
      foreach(pin_conflict pins_conflicts
       if( pin_conflict == pin then
        printf("\n " pin_conflict_id~>name pin_conflict_id~>lpp centerBox(pin_conflict_id~>fig~>bBox))
       );if
      ) ;for
     ) ;for
    ) ;proc
    Best regards,
    Marben
  • LakshmanQual
    Hi Marben,
    A kind of same. But no need to compare with actual pins of layouts.
    But where can i get "pin_conflict_id" in your script?
  • Marben
    Something like this.
    pins_conflict_id = setof(x pins x~>name == "inp" || x~>name == "inm" || x~>name == "out" || x~>name == "vdd" || x~>name == "vss")
    Best regards,
    Marben
    Are you really using the pin names, or the terminal names? The pin names aren't normally that important in a layout - it's the terminal names that matter. If you are trying to identify the pins from the pin names you'd use:
    foreach(term cvId~>terminals
        when(member(pin~>name pins_conflicts)
            printf("%L %L %L\n" pin~>name pinFig~>lpp centerBox(pinFig~>bBox))
    or something like that.
  • LakshmanQual
    Its working exactly what i want.
    Can we find all the lpp and Bbox of those pins which are repeated in the above 'pins_conflicts' list?
