  3. determine if an object is part of a ROD
  • Views 16284
drdanmc
drdanmc over 8 years ago
Is there a clean way to tell if a shape in a cellview is part of a ROD (actually MPP is what I'm interested in but other forum answers talk about that piece).
foreach(fig cv->shapes
  when(shape_is_part_of_rod(fig)    ;; <--- any simple way to do this?
    printf("I am a %L that is part of a ROD\n", fig->objType)
I can picture some crazy things like making a table that I populate with all shapes by iterating on RODs and then subShapes and then see if a given figure ID is found in that big table but that seems like a lot of work for a simple check.
-Dan
    Andrew Beckett over 8 years ago +1
    Hi Dan, I don't think there is a simple function to do this. I searched back and found I'd answered this as follows for a customer a few years ago: The only way I can think of doing this is to do something…
    Hi Dan,
    The only way I can think of doing this is to do something like:
    procedure(abIsObjPartOfMPP(obj)
      (rodGetObj(obj) || exists(rodId rodGetNamedShapes(obj~>cellView)
        member(obj rodId~>subShapes)
      )) && t
    If doing this repeatedly, it would probably be more efficient to cache all the subShapes in a table so you can use a hash lookup instead of using member (which will be less efficient). But I'll leve that as an exercise for you!
  • drdanmc
    drdanmc over 8 years ago in reply to Andrew Beckett
    Thanks.  I ended up iterating over the MPPs and then over the subShapes and put them in a table to be able to lookup the dbID of the main MPP from any of the sub shapes.
    -Dan
