  3. hiRegTimer is not calling my procedure
  • Views 18145
WTony
WTony over 8 years ago
Hi all,
I'm trying to use hiRegtimer to pause my code without blocking my virtuoso session
my code:
procedure(yhwDeleteLabel(yhwText)
 let((yhwCV yhwLabel)
  yhwCV = geGetWindowCellView()
  yhwLabel = setof(l yhwCV~>shapes l~>theLabel==yhwText && l~>track)
  if(yhwLabel then
   dbDeleteObject(car(yhwLabel))
  yhwText = "netA"
  hiRegTimer("yhwDeleteLabel(yhwText)" 10)
it never go inside my procedure. if I call yhwDeleteLabel(yhwText) without hiRegTimer then it works. What is wrong in my code.
I also tried to use ipcsleep() but it block my virtuoso session.
the purpose of the code was to show an info message in the layout session then disappear after 1 second display.
    It works for me - however, it doesn't seem to cause the window to refresh, so maybe you need to call hiRedraw() or something like that after the call to your function. I found that without this I need to move my cursor around in the window and then the text appears to vanish (it's gone, but the window doesn't refresh immediately).
  • WTony
    WTony over 8 years ago in reply to Andrew Beckett
    hi Andrew,
    I tried to debug with SKILL IDE tool and it show clearly that it didn't call my procedure
    i include my 3 procedure:
    procedure(yhwInfo(yhwText)
    let((cv winBox edgeAdjustX edgeAdjustY textAdjust x y textSize yhwLabel)
    cv=geGetWindowCellView()
    yhwLabelsDelete(cv)
    leSetLayerVisible(list("ALPHA" "drawing") t)
    winBox = geGetWindowBox(hiGetCurrentWindow())
    edgeAdjustX=0.02 ; 2% of horizontal display size
    edgeAdjustY=0.04
    textAdjust=0.023 ; 2.3% of vertical display size
    x=leftEdge(winBox)+(rightEdge(winBox)-leftEdge(winBox))*edgeAdjustX
    y=topEdge(winBox)-(topEdge(winBox)-bottomEdge(winBox))*edgeAdjustY
    textSize=(topEdge(winBox)-bottomEdge(winBox))*textAdjust
    yhwLabel = dbCreateLabel(cv "ALPHA" x:y yhwText "centerLeft" "R0" "roman" textSize)
    dbCreateProp(yhwLabel "track" "boolean" t)
    procedure(yhwLabelsDelete(cv)
    let((yhwLabels)
    yhwLabels = setof(l cv~>shapes l~>objType=="label" && l~>track)
    if(yhwLabels then
    foreach(item yhwLabels
    dbDeleteObject(item)
    let((yhwCV yhwFindLabel)
    info("\n*****%s*****\n" yhwText)
    yhwFindLabel = setof(l yhwCV~>shapes l~>theLabel==yhwText && l~>track)
    if(yhwFindLabel then
    info("DELETE\n")
    dbDeleteObject(car(yhwFindLabel))
    yhwText = nil
    hiRedraw()
    from the IDE tool message:
    <<< Break >>> on explicit 'break' request
    Entering new debug toplevel due to breakpoint:
    stopped before evaluating (winBox = geGetWindowBox(hiGetCurrentWindow()))
    stopped before evaluating (edgeAdjustX = 0.02)
    stopped before evaluating (edgeAdjustY = 0.04)
    stopped before evaluating (textAdjust = 0.023)
    stopped before evaluating (x = (leftEdge(winBox) + ((& - &) * edgeAdjustX)))
    stopped before evaluating (y = (topEdge(winBox) - ((& - &) * edgeAdjustY)))
    stopped before evaluating (textSize = ((topEdge(winBox) - bottomEdge(winBox)) * textAdjust))
    stopped before evaluating (yhwLabel = dbCreateLabel(cv "ALPHA" (x:y) yhwText "centerLeft" ... ))
    stopped before evaluating dbCreateProp(yhwLabel "track" "boolean" t)
    stopped before evaluating hiRegTimer("yhwDeleteLabel(yhwText)" 10)
    <<< Exiting yhwInfo >>>
    for some reason, it didn't call my procedure yhwDeleteLabel.
    Tony
    Andrew Beckett over 8 years ago in reply to WTony
    Hi Tony,
    From this, I'm not sure how you can conclude that it didn't call your function - assuming you're single stepping in the debugger, it wouldn't single step into the callback in hiRegTimer anyway, because that's executed from when the UI updates, not from the code sequence you're running in the debugger. It probably would have been better to do:
    trace(yhwDeleteLabel)
    However, having seen the full code, the issue will be that yhwText won't be in scope at the time the function is called. It's an argument to yhwInfo and that will have returned (and so the scope will have ended) by the time the hiRegTimer string is invoked. Even then, it would have been evaluated in the global scope - so you wouldn't have that variable defined (probably).
    It might be better to change the code line to:
    hiRegTimer(sprintf(nil "yhwDeleteLabel(%L)"  yhwText) 10)
    What that would do is change the call in the timer to have the literal string that was passed into the function - so there's no dependency on using (say) a global variable to track the string.
    You could also use:
    _stacktrace=50
    sstatus(errsetTrace t)
    to see if the hiRegTimer is calling the expression but failing with an error.
  • WTony
    You are right, after changing to your line. it works perfectly.
    Thanks so much
    Tony
